주요 콘텐츠로 건너뛰기
HP Envy x360 15m-bp111dx Charging Port Replacement
필요한 것
  1. HP Envy x360 15m-bp111dx Charging Port Replacement, Back Panel: 1 단계, 이미지 1/2 HP Envy x360 15m-bp111dx Charging Port Replacement, Back Panel: 1 단계, 이미지 2/2
    • Remove the rubber feet to access the screws.
    • Using a Phillips #0 screwdriver, remove the four 7 mm screws.
    • Using a T5 Torx screwdriver, remove the three 5 mm screws.
  2. HP Envy x360 15m-bp111dx Charging Port Replacement: 2 단계, 이미지 1/3 HP Envy x360 15m-bp111dx Charging Port Replacement: 2 단계, 이미지 2/3 HP Envy x360 15m-bp111dx Charging Port Replacement: 2 단계, 이미지 3/3
    • Insert opening picks or an opening tool inside the edge of the chassis to separate the back panel from the rest of the computer.
    • You may hear snapping as the clips are released while you work your way around the perimeter of the computer. This is normal.
    • Remove the back case.
  3. HP Envy x360 15m-bp111dx Charging Port Replacement, Charging Port: 3 단계, 이미지 1/3 HP Envy x360 15m-bp111dx Charging Port Replacement, Charging Port: 3 단계, 이미지 2/3 HP Envy x360 15m-bp111dx Charging Port Replacement, Charging Port: 3 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to remove the two M2x3.1 screws that secure the speaker in place.
    • Lift and move the speaker to the side.
    • Do not pull too hard on the speaker. It is connected by thin wires that run under the motherboard.
  4. HP Envy x360 15m-bp111dx Charging Port Replacement: 4 단계, 이미지 1/2 HP Envy x360 15m-bp111dx Charging Port Replacement: 4 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove remove three M2.5x4 screws that secure the hinge.
  5. HP Envy x360 15m-bp111dx Charging Port Replacement: 5 단계, 이미지 1/1
    • Use the opening tool to raise the hinge.
    • Then lift the hinge by hand to provide enough clearance to remove the charging port.
    • Be careful when lifting the hinge. The back can be bent and damaged if raised too far.
  6. HP Envy x360 15m-bp111dx Charging Port Replacement: 6 단계, 이미지 1/2 HP Envy x360 15m-bp111dx Charging Port Replacement: 6 단계, 이미지 2/2
    • Gently slide the charging port connector out of the port, and lift it above the hinge.
  7. HP Envy x360 15m-bp111dx Charging Port Replacement: 7 단계, 이미지 1/3 HP Envy x360 15m-bp111dx Charging Port Replacement: 7 단계, 이미지 2/3 HP Envy x360 15m-bp111dx Charging Port Replacement: 7 단계, 이미지 3/3
    • Grasp the sliding connector on the motherboard and remove it from the socket.
  8. HP Envy x360 15m-bp111dx Charging Port Replacement: 8 단계, 이미지 1/1
    • Remove the charging port.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tori Luongo
회원 가입일: 02/22/22
268 평판
안내서 2개 작성하였습니다
Clemson, Team 2-2, Hunter Spring 2022 Clemson, Team 2-2, Hunter Spring 2022 회원
CLEM-HUNTER-S22S2G2
5 회원들
안내서 6개 작성하였습니다
댓글 한 개
What is a typical charge for a technician to replace the charging port and what should a typical charging port cost?
Robert Ford - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 15
30일 전: 36
전체 시간: 575
