주요 콘텐츠로 건너뛰기
HP Envy x360 15m-bp111dx Touchpad Replacement
필요한 것
  1. HP Envy x360 15m-bp111dx Touchpad Replacement, Back Panel: 1 단계, 이미지 1/2 HP Envy x360 15m-bp111dx Touchpad Replacement, Back Panel: 1 단계, 이미지 2/2
    • Remove the rubber feet to access the screws.
    • Using a Phillips #0 screwdriver, remove the four 7 mm screws.
    • Using a T5 Torx screwdriver, remove the three 5 mm screws.
  2. HP Envy x360 15m-bp111dx Touchpad Replacement: 2 단계, 이미지 1/3 HP Envy x360 15m-bp111dx Touchpad Replacement: 2 단계, 이미지 2/3 HP Envy x360 15m-bp111dx Touchpad Replacement: 2 단계, 이미지 3/3
    • Insert opening picks or an opening tool inside the edge of the chassis to separate the back panel from the rest of the computer.
    • You may hear snapping as the clips are released while you work your way around the perimeter of the computer. This is normal.
    • Remove the back case.
  3. HP Envy x360 15m-bp111dx Touchpad Replacement, Battery: 3 단계, 이미지 1/2 HP Envy x360 15m-bp111dx Touchpad Replacement, Battery: 3 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the seven 4 mm screws securing the battery.
  4. HP Envy x360 15m-bp111dx Touchpad Replacement: 4 단계, 이미지 1/3 HP Envy x360 15m-bp111dx Touchpad Replacement: 4 단계, 이미지 2/3 HP Envy x360 15m-bp111dx Touchpad Replacement: 4 단계, 이미지 3/3
    • Carefully lift the battery, and pull it towards you to remove it.
  5. HP Envy x360 15m-bp111dx Touchpad Replacement, Touchpad: 5 단계, 이미지 1/3 HP Envy x360 15m-bp111dx Touchpad Replacement, Touchpad: 5 단계, 이미지 2/3 HP Envy x360 15m-bp111dx Touchpad Replacement, Touchpad: 5 단계, 이미지 3/3
    • Use a Phillips screwdriver to remove the four 3.5 mm screws securing the bar on the touchpad.
    • Remove the bar from the touchpad.
  6. HP Envy x360 15m-bp111dx Touchpad Replacement: 6 단계, 이미지 1/2 HP Envy x360 15m-bp111dx Touchpad Replacement: 6 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the three 2 mm screws securing the touchpad.
  7. HP Envy x360 15m-bp111dx Touchpad Replacement: 7 단계, 이미지 1/3 HP Envy x360 15m-bp111dx Touchpad Replacement: 7 단계, 이미지 2/3 HP Envy x360 15m-bp111dx Touchpad Replacement: 7 단계, 이미지 3/3
    • Flip the lock open on the ZIF connector using the opening tool to detach the ribbon from the motherboard.
    • Gently remove the touchpad from the motherboard.
  8. HP Envy x360 15m-bp111dx Touchpad Replacement: 8 단계, 이미지 1/1
    • The touchpad is now removed.
결론
Haley Holmes
회원 가입일: 02/22/22
109 평판
안내서 1개 작성함
Clemson, Team 2-2, Hunter Spring 2022 Clemson, Team 2-2, Hunter Spring 2022 회원
CLEM-HUNTER-S22S2G2
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 11
전체 시간: 239
