소개
Is the touchpad not working for your HP Envy x360 15m-bp111dx laptop? If so, follow this guide to get it fixed in just a few steps.
This guide will assist in locating, removing, and replacing the touchpad of your HP Envy x360 15m-bp111dx. You may need to utilize this guide if the touchpad has become unresponsive. Be sure to troubleshoot your HP Envy x360 15m-bp111dx before beginning this replacement.
Additionally, make sure that your laptop is powered off, it's unplugged from the power adapter, and that the components have cooled before replacing the touchpad.
필요한 것
Remove the rubber feet to access the screws.
Using a Phillips #0 screwdriver, remove the four 7 mm screws.
Using a T5 Torx screwdriver, remove the three 5 mm screws.
Use a Phillips screwdriver to remove the four 3.5 mm screws securing the bar on the touchpad.
Remove the bar from the touchpad.
