소개
Use this guide to replace the speakers for the HP Envy x360 15m-bp112dx. Speakers are used to emit sound or songs from a laptop. These should be replaced if there are issues with the audio, the sound is distorted, or no audio comes out.
필요한 것
Start by facing the device upside down with the hinge facing away from you.
Remove the seven 1 mm Phillips screws.
Remove the two 5 mm Phillips screws from the first speaker.
Carefully peel back the tape.
Remove the two 1.5 mm Phillips screws.
Carefully peel the tape back.
Pull the left speaker cord around the plastic clips.
