주요 콘텐츠로 건너뛰기
HP Envy x360 15m-bq021dx Cooling Fan Replacement
필요한 것
  1. HP Envy x360 15m-bq021dx Cooling Fan Replacement, Battery: 1 단계, 이미지 1/2 HP Envy x360 15m-bq021dx Cooling Fan Replacement, Battery: 1 단계, 이미지 2/2
    • On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq021dx Cooling Fan Replacement: 2 단계, 이미지 1/3 HP Envy x360 15m-bq021dx Cooling Fan Replacement: 2 단계, 이미지 2/3 HP Envy x360 15m-bq021dx Cooling Fan Replacement: 2 단계, 이미지 3/3
    • To remove the back cover, use the black spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
  3. HP Envy x360 15m-bq021dx Cooling Fan Replacement: 3 단계, 이미지 1/1
    • Use the Philips #0 screwdriver to remove six (6) M2.0x3.2 screws from battery.
  4. HP Envy x360 15m-bq021dx Cooling Fan Replacement: 4 단계, 이미지 1/1
    • Using the Philips #0 screwdriver, remove the final screw from the battery connected to the SSD storage unit.
  5. HP Envy x360 15m-bq021dx Cooling Fan Replacement: 5 단계, 이미지 1/1
    • Lift and pull the front of the battery up and out (away from the connector) to remove.
  6. HP Envy x360 15m-bq021dx Cooling Fan Replacement, Cooling Fan: 6 단계, 이미지 1/2 HP Envy x360 15m-bq021dx Cooling Fan Replacement, Cooling Fan: 6 단계, 이미지 2/2
    • Using a Philips #0 screwdriver, remove the three M2x4 screws located around the cooling fan as shown in this picture.
    • Be careful as the fan might be sharp in some places when removing it.
  7. HP Envy x360 15m-bq021dx Cooling Fan Replacement: 7 단계, 이미지 1/2 HP Envy x360 15m-bq021dx Cooling Fan Replacement: 7 단계, 이미지 2/2
    • Remove the connector clip with the tweezers.
  8. HP Envy x360 15m-bq021dx Cooling Fan Replacement: 8 단계, 이미지 1/1
    • Remove the four spring loaded screws with a Philips #1 screwdriver.
  9. HP Envy x360 15m-bq021dx Cooling Fan Replacement: 9 단계, 이미지 1/2 HP Envy x360 15m-bq021dx Cooling Fan Replacement: 9 단계, 이미지 2/2
    • Remove the cooling fan.
결론
다른 2명이 해당 안내서를 완성하였습니다.
SALMAN ALOTAIBI
회원 가입일: 09/04/19
139 평판
안내서 1개 작성함
University of Alabama, Team S2-G6, Bedsole Fall 2019 University of Alabama, Team S2-G6, Bedsole Fall 2019 회원
UA-BEDSOLE-F19S2G6
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
I'm considering attempting this repair. I am curious as to why the instructions direct me to remove the battery before removing the fan. From the pictures shown above, it does not appear that battery is mechanically blocking the removal of the fan. Is the purpose of this step to remove a phisical impedance, or is the reason to remove power from the he device?
Daniel Abrams - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 9
전체 시간: 949
