소개
Hard drives can become damaged or faulty over time, or can just have too little memory or be too slow. follow this guide to replace your hard drive.
필요한 것
On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
Use the tweezers to lift up the retaining flap on the cable connector.
Pull out the ribbon cable from the connector.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Followed guide to remove HDD from 15m-bq121dx model. Steps were identical. Took more force than I expected to remove bottom cover and to get the HDD out.
