주요 콘텐츠로 건너뛰기
HP Envy x360 15m-bq021dx Motherboard Replacement
필요한 것
  1. HP Envy x360 15m-bq021dx Motherboard Replacement, Battery: 1 단계, 이미지 1/2 HP Envy x360 15m-bq021dx Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq021dx Motherboard Replacement: 2 단계, 이미지 1/3 HP Envy x360 15m-bq021dx Motherboard Replacement: 2 단계, 이미지 2/3 HP Envy x360 15m-bq021dx Motherboard Replacement: 2 단계, 이미지 3/3
    • To remove the back cover, use the black spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
  3. HP Envy x360 15m-bq021dx Motherboard Replacement: 3 단계, 이미지 1/1
    • Use the Philips #0 screwdriver to remove six (6) M2.0x3.2 screws from battery.
  4. HP Envy x360 15m-bq021dx Motherboard Replacement: 4 단계, 이미지 1/1
    • Using the Philips #0 screwdriver, remove the final screw from the battery connected to the SSD storage unit.
  5. HP Envy x360 15m-bq021dx Motherboard Replacement: 5 단계, 이미지 1/1
    • Lift and pull the front of the battery up and out (away from the connector) to remove.
  6. HP Envy x360 15m-bq021dx Motherboard Replacement, Cooling Fan: 6 단계, 이미지 1/2 HP Envy x360 15m-bq021dx Motherboard Replacement, Cooling Fan: 6 단계, 이미지 2/2
    • Using a Philips #0 screwdriver, remove the three M2x4 screws located around the cooling fan as shown in this picture.
    • Be careful as the fan might be sharp in some places when removing it.
  7. HP Envy x360 15m-bq021dx Motherboard Replacement: 7 단계, 이미지 1/2 HP Envy x360 15m-bq021dx Motherboard Replacement: 7 단계, 이미지 2/2
    • Remove the connector clip with the tweezers.
  8. HP Envy x360 15m-bq021dx Motherboard Replacement: 8 단계, 이미지 1/1
    • Remove the four spring loaded screws with a Philips #1 screwdriver.
  9. HP Envy x360 15m-bq021dx Motherboard Replacement: 9 단계, 이미지 1/2 HP Envy x360 15m-bq021dx Motherboard Replacement: 9 단계, 이미지 2/2
    • Remove the cooling fan.
  10. HP Envy x360 15m-bq021dx Motherboard Replacement, Motherboard: 10 단계, 이미지 1/3 HP Envy x360 15m-bq021dx Motherboard Replacement, Motherboard: 10 단계, 이미지 2/3 HP Envy x360 15m-bq021dx Motherboard Replacement, Motherboard: 10 단계, 이미지 3/3
    • Using a Phillips #1, remove the seven M2.0x3.2 screws.
    • Undo the six connections using the blue opening tool.
  11. HP Envy x360 15m-bq021dx Motherboard Replacement: 11 단계, 이미지 1/3 HP Envy x360 15m-bq021dx Motherboard Replacement: 11 단계, 이미지 2/3 HP Envy x360 15m-bq021dx Motherboard Replacement: 11 단계, 이미지 3/3
    • Carefully remove the aux port from the frame of the computer as shown.
  12. HP Envy x360 15m-bq021dx Motherboard Replacement: 12 단계, 이미지 1/2 HP Envy x360 15m-bq021dx Motherboard Replacement: 12 단계, 이미지 2/2
    • Pull the mother board up and away from frame of the computer.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Hunter Reihart
회원 가입일: 09/04/19
506 평판
안내서 3개 작성하였습니다
University of Alabama, Team S2-G6, Bedsole Fall 2019 University of Alabama, Team S2-G6, Bedsole Fall 2019 회원
UA-BEDSOLE-F19S2G6
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
hi so i was woundering about the start button , mine is broken , is there a way to start uo the pc and can i hook up a poer button some how to start it up thanks
gadget1961 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 1,541
