주요 콘텐츠로 건너뛰기
HP Envy x360 15m-bq021dx RAM Replacement
필요한 것
  1. HP Envy x360 15m-bq021dx RAM Replacement, Battery: 1 단계, 이미지 1/2 HP Envy x360 15m-bq021dx RAM Replacement, Battery: 1 단계, 이미지 2/2
    • On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq021dx RAM Replacement: 2 단계, 이미지 1/3 HP Envy x360 15m-bq021dx RAM Replacement: 2 단계, 이미지 2/3 HP Envy x360 15m-bq021dx RAM Replacement: 2 단계, 이미지 3/3
    • To remove the back cover, use the black spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
  3. HP Envy x360 15m-bq021dx RAM Replacement: 3 단계, 이미지 1/1
    • Use the Philips #0 screwdriver to remove six (6) M2.0x3.2 screws from battery.
  4. HP Envy x360 15m-bq021dx RAM Replacement: 4 단계, 이미지 1/1
    • Using the Philips #0 screwdriver, remove the final screw from the battery connected to the SSD storage unit.
  5. HP Envy x360 15m-bq021dx RAM Replacement: 5 단계, 이미지 1/1
    • Lift and pull the front of the battery up and out (away from the connector) to remove.
  6. HP Envy x360 15m-bq021dx RAM Replacement, RAM: 6 단계, 이미지 1/1
    • Remove the tape near the RAM storage.
  7. HP Envy x360 15m-bq021dx RAM Replacement: 7 단계, 이미지 1/2 HP Envy x360 15m-bq021dx RAM Replacement: 7 단계, 이미지 2/2
    • Use a small blue opening tool to pry open the protective metal cover.
  8. HP Envy x360 15m-bq021dx RAM Replacement: 8 단계, 이미지 1/1
    • Pull on the silver pins away from the RAM on both sides.
  9. HP Envy x360 15m-bq021dx RAM Replacement: 9 단계, 이미지 1/2 HP Envy x360 15m-bq021dx RAM Replacement: 9 단계, 이미지 2/2
    • Pull the RAM up and out to remove.
결론
Hunter Reihart
회원 가입일: 09/04/19
506 평판
안내서 3개 작성하였습니다
University of Alabama, Team S2-G6, Bedsole Fall 2019 University of Alabama, Team S2-G6, Bedsole Fall 2019 회원
UA-BEDSOLE-F19S2G6
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 12
전체 시간: 1,639
