주요 콘텐츠로 건너뛰기
HP Envy x360 15m-bq121dx Cooling Fan Replacement
필요한 것
  1. HP Envy x360 15m-bq121dx Cooling Fan Replacement, Cooling Fan: 1 단계, 이미지 1/2 HP Envy x360 15m-bq121dx Cooling Fan Replacement, Cooling Fan: 1 단계, 이미지 2/2
    • Be sure the computer is powered off.
    • Remove the rubber strip along the top of the backside of the computer.
    • On the back panel of the device, remove the four (4) 2.5 mm screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq121dx Cooling Fan Replacement: 2 단계, 이미지 1/3 HP Envy x360 15m-bq121dx Cooling Fan Replacement: 2 단계, 이미지 2/3 HP Envy x360 15m-bq121dx Cooling Fan Replacement: 2 단계, 이미지 3/3
    • To remove the back cover, use the spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
    • Be sure to not damage any of the electronics on the inside.
  3. HP Envy x360 15m-bq121dx Cooling Fan Replacement: 3 단계, 이미지 1/1
    • Use the Philips #0 screwdriver to remove seven 2 mm screws from battery.
  4. HP Envy x360 15m-bq121dx Cooling Fan Replacement: 4 단계, 이미지 1/1
    • Lift and pull the front of the battery up and out away from the connector to remove.
  5. HP Envy x360 15m-bq121dx Cooling Fan Replacement: 5 단계, 이미지 1/2 HP Envy x360 15m-bq121dx Cooling Fan Replacement: 5 단계, 이미지 2/2
    • Using a Philips #0 screwdriver, remove the three 2 mm screws located around the cooling fan as shown in this picture.
    • The fan may have sharp edges so be careful upon removal.
  6. HP Envy x360 15m-bq121dx Cooling Fan Replacement: 6 단계, 이미지 1/2 HP Envy x360 15m-bq121dx Cooling Fan Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Remove the connector clip with the tweezers.
  7. HP Envy x360 15m-bq121dx Cooling Fan Replacement: 7 단계, 이미지 1/1
    • Remove the four spring loaded screws with a Philips #1 screwdriver.
  8. HP Envy x360 15m-bq121dx Cooling Fan Replacement: 8 단계, 이미지 1/2 HP Envy x360 15m-bq121dx Cooling Fan Replacement: 8 단계, 이미지 2/2
    • Remove the cooling fan.
결론
Fabien Perez
회원 가입일: 02/13/20
157 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 37
전체 시간: 1,826
