주요 콘텐츠로 건너뛰기
HP Envy x360 15m-cn0012dx Fan Replacement
필요한 것
  1. HP Envy x360 15m-cn0012dx  Fan Replacement, Fan: 1 단계, 이미지 1/2 HP Envy x360 15m-cn0012dx  Fan Replacement, Fan: 1 단계, 이미지 2/2
    • Make sure the computer is turned off, and remove all cables.
    • Set the laptop face down.
    • Peel back the grey screw guards, along the top and bottom edge of the back case. It may be helpful to use a spudger to get started.
    • Peel slowly to avoid tearing the rubber covers.
  2. HP Envy x360 15m-cn0012dx  Fan Replacement: 2 단계, 이미지 1/3 HP Envy x360 15m-cn0012dx  Fan Replacement: 2 단계, 이미지 2/3 HP Envy x360 15m-cn0012dx  Fan Replacement: 2 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver, remove the seven 5mm screws from the back case.
  3. HP Envy x360 15m-cn0012dx  Fan Replacement: 3 단계, 이미지 1/3 HP Envy x360 15m-cn0012dx  Fan Replacement: 3 단계, 이미지 2/3 HP Envy x360 15m-cn0012dx  Fan Replacement: 3 단계, 이미지 3/3
    • Pry open the back cover using the iFixit Opening Tool.
    • While using the tool, place a pick at each corner of the computer (be careful and do it slowly).
    • Once all the corners are slightly lifted, carefully pop off the back cover.
  4. HP Envy x360 15m-cn0012dx  Fan Replacement: 4 단계, 이미지 1/3 HP Envy x360 15m-cn0012dx  Fan Replacement: 4 단계, 이미지 2/3 HP Envy x360 15m-cn0012dx  Fan Replacement: 4 단계, 이미지 3/3
    • Remove the two 4mm screws from the fan using a Phillips #0 screwdriver.
    • Peel the tape off of the multicolor cable bundle connecting the fan to the motherboard.
    • Use the iFixit opening tool to disconnect the connector.
  5. HP Envy x360 15m-cn0012dx  Fan Replacement: 5 단계, 이미지 1/2 HP Envy x360 15m-cn0012dx  Fan Replacement: 5 단계, 이미지 2/2
    • Peel back the tape from the heatsink.
    • Use the Phillips #0 screwdriver to remove the four captive screws from the heatsink.
    • These screws will stay inside the heatsink while it is removed, simply loosen them until they disengage from the case and the heatsink becomes loose.
  6. HP Envy x360 15m-cn0012dx  Fan Replacement: 6 단계, 이미지 1/2 HP Envy x360 15m-cn0012dx  Fan Replacement: 6 단계, 이미지 2/2
    • Unlatch the black cable from the plastic guides on the fan.
    • Lift the fan from the laptop case.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ross Jeseritz
회원 가입일: 02/04/20
157 평판
안내서 1개 작성함
UW Stout, Team S1-G3, Schneider-Bateman Spring 2020 UW Stout, Team S1-G3, Schneider-Bateman Spring 2020 회원
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G3
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
You didn't show how to remove the Fan. You removed the Fan and Heat Sink. There's 4 more screws. Finish the job.
philw395 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 20
30일 전: 67
전체 시간: 2,843
