주요 콘텐츠로 건너뛰기
HP Envy x360 15m-cn0012dx Hard Drive Replacement
필요한 것
  1. HP Envy x360 15m-cn0012dx Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/2 HP Envy x360 15m-cn0012dx Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/2
    • Make sure the computer is turned off, and remove all cables.
    • Set the laptop face down.
    • Peel back the grey screw guards, along the top and bottom edge of the back case. It may be helpful to use a spudger to get started.
    • Peel slowly to avoid tearing the rubber covers.
  2. HP Envy x360 15m-cn0012dx Hard Drive Replacement: 2 단계, 이미지 1/3 HP Envy x360 15m-cn0012dx Hard Drive Replacement: 2 단계, 이미지 2/3 HP Envy x360 15m-cn0012dx Hard Drive Replacement: 2 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver, remove the seven 5mm screws from the back case.
  3. HP Envy x360 15m-cn0012dx Hard Drive Replacement: 3 단계, 이미지 1/3 HP Envy x360 15m-cn0012dx Hard Drive Replacement: 3 단계, 이미지 2/3 HP Envy x360 15m-cn0012dx Hard Drive Replacement: 3 단계, 이미지 3/3
    • Pry open the back cover using the iFixit Opening Tool.
    • While using the tool, place a pick at each corner of the computer (be careful and do it slowly).
    • Once all the corners are slightly lifted, carefully pop off the back cover.
  4. HP Envy x360 15m-cn0012dx Hard Drive Replacement: 4 단계, 이미지 1/2 HP Envy x360 15m-cn0012dx Hard Drive Replacement: 4 단계, 이미지 2/2
    • Use the Phillips #0 screwdriver to remove one screw from the bottom left corner of the laptop.
    • Use the iFixit opening tool to lift the latch and detach the connector to the motherboard.
    • Remove the hard drive.
    • When replacing the hard drive, you will likely have to transfer the SATA cable and hardware from your old drive to the new one before reinstalling.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Grace Daleki
회원 가입일: 02/04/20
475 평판
안내서 3개 작성하였습니다
UW Stout, Team S1-G3, Schneider-Bateman Spring 2020 UW Stout, Team S1-G3, Schneider-Bateman Spring 2020 회원
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G3
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 28
30일 전: 101
전체 시간: 5,313
