주요 콘텐츠로 건너뛰기
HP Envy x360 m6-aq003dx Battery Replacement
필요한 것
  1. HP Envy x360 m6-aq003dx Battery Replacement, Back Panel: 1 단계, 이미지 1/3 HP Envy x360 m6-aq003dx Battery Replacement, Back Panel: 1 단계, 이미지 2/3 HP Envy x360 m6-aq003dx Battery Replacement, Back Panel: 1 단계, 이미지 3/3
    • Turn the laptop over and use the plastic opening tool to take off the rubber pads. You only need to take off the two pads at the top for this device.
  2. HP Envy x360 m6-aq003dx Battery Replacement: 2 단계, 이미지 1/3 HP Envy x360 m6-aq003dx Battery Replacement: 2 단계, 이미지 2/3 HP Envy x360 m6-aq003dx Battery Replacement: 2 단계, 이미지 3/3
    • Use the Torx T5 screwdriver to remove the six small screws.
    • Use the Phillips #0 screwdriver to remove the screws under the rubber pads in step 1.
  3. HP Envy x360 m6-aq003dx Battery Replacement: 3 단계, 이미지 1/1
    • Go slowly around the edge with the opening tool. The noises you will hear are due to the small joints popping open. Continue this until you have made your way around the entire laptop.
  4. HP Envy x360 m6-aq003dx Battery Replacement, Battery: 4 단계, 이미지 1/2 HP Envy x360 m6-aq003dx Battery Replacement, Battery: 4 단계, 이미지 2/2
    • Remove the six 4mm screws around the battery using a Phillips #0 screwdriver.
  5. HP Envy x360 m6-aq003dx Battery Replacement: 5 단계, 이미지 1/1
    • Disconnect the white connector from the battery to the board. (It is recommended to use pliers to remove the cord to avoid touching the board).
    • Once the connector and screws are both removed, lift the battery up and remove it from the laptop.
    • The removal of the connector and the screws can be done in either order.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Paris Williams
회원 가입일: 09/25/19
157 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 13
전체 시간: 934
