주요 콘텐츠로 건너뛰기
HP Envy x360 m6-aq005dx Battery Replacement
필요한 것
  1. HP Envy x360 m6-aq005dx Battery Replacement, Back Panel: 1 단계, 이미지 1/2 HP Envy x360 m6-aq005dx Battery Replacement, Back Panel: 1 단계, 이미지 2/2
    • Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top.
  2. HP Envy x360 m6-aq005dx Battery Replacement: 2 단계, 이미지 1/3 HP Envy x360 m6-aq005dx Battery Replacement: 2 단계, 이미지 2/3 HP Envy x360 m6-aq005dx Battery Replacement: 2 단계, 이미지 3/3
    • Use a Torx T5 screwdriver to remove the six 5.1 mm screws.
    • Use a JIS #1 screwdriver to remove the two 7.2mm screws.
  3. HP Envy x360 m6-aq005dx Battery Replacement: 3 단계, 이미지 1/1
    • Use a plastic opening tool to pry open the case. Go slowly around the edge. You will hear popping noises, such are due to popping open the small joints that keep the cover attached.
  4. HP Envy x360 m6-aq005dx Battery Replacement, Battery: 4 단계, 이미지 1/2 HP Envy x360 m6-aq005dx Battery Replacement, Battery: 4 단계, 이미지 2/2
    • Use a JIS #1 screwdriver to remove the six 4.7 mm screws.
  5. HP Envy x360 m6-aq005dx Battery Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Battery might cause a small electric shock.
    • Use tweezers to disconnect the battery from the motherboard.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Matthew Martin
회원 가입일: 10/10/17
711 평판
안내서 5개 작성하였습니다
USF Tampa, Team S13-G17, Cagle Fall 2017 USF Tampa, Team S13-G17, Cagle Fall 2017 회원
USFT-CAGLE-F17S13G17
4 회원들
안내서 7개 작성하였습니다
댓글 3개
Step 3 was the toughest!!! Case was difficult to separate.
Bo Hagen - 답글
Thank you!!!! This made it sooooo easy to replace my battery!
Michelle Kuhlmann - 답글
Excellent guide, many thanks for posting it.
stephenm.race - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 30
전체 시간: 15,596
