소개
The battery is the main power source for the laptop when not plugged in. The battery may contain a small amount of electric charge, so this guide will provide assistance in the battery's proper and safe removal.
필요한 것
Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 3개
Thank you!!!! This made it sooooo easy to replace my battery!
Excellent guide, many thanks for posting it.
