주요 콘텐츠로 건너뛰기
HP Envy x360 m6-aq005dx Keyboard Replacement
필요한 것
  1. HP Envy x360 m6-aq005dx Keyboard Replacement, Keyboard: 1 단계, 이미지 1/3 HP Envy x360 m6-aq005dx Keyboard Replacement, Keyboard: 1 단계, 이미지 2/3 HP Envy x360 m6-aq005dx Keyboard Replacement, Keyboard: 1 단계, 이미지 3/3
    • Use the Phillips #0 screw driver head to remove the two 7.8mm screws that secure the bottom cover to the computer.
    • Use the Phillips #00 screw driver head to remove the six 5.2mm screws that secure the bottom cover to the computer.
    • Insert the iFixit plastic prying tool between the bottom cover and bottom chassis.
    • Lift the cover carefully off the machine.
  2. HP Envy x360 m6-aq005dx Keyboard Replacement: 2 단계, 이미지 1/3 HP Envy x360 m6-aq005dx Keyboard Replacement: 2 단계, 이미지 2/3 HP Envy x360 m6-aq005dx Keyboard Replacement: 2 단계, 이미지 3/3
    • Use the Phillips #00 screw driver head to remove the six 4.6mm screws that secure the battery to the top cover.
    • Disconnect the battery cable from the motherboard.
    • Lift to remove the battery and set it to the side.
  3. HP Envy x360 m6-aq005dx Keyboard Replacement: 3 단계, 이미지 1/3 HP Envy x360 m6-aq005dx Keyboard Replacement: 3 단계, 이미지 2/3 HP Envy x360 m6-aq005dx Keyboard Replacement: 3 단계, 이미지 3/3
    • Use the Phillips #00 screw driver head to remove the three 4.6mm screws that secure the fan to the top cover.
    • Release the display panel cable from the retention clips and channel built into the fan.
    • Use the Phillips #0 screw driver head to remove the four 6.2mm captive screws that secure the fan/ heat sink assembly to the motherboard.
    • Remove the fan/heat sink assembly.
  4. HP Envy x360 m6-aq005dx Keyboard Replacement: 4 단계, 이미지 1/3 HP Envy x360 m6-aq005dx Keyboard Replacement: 4 단계, 이미지 2/3 HP Envy x360 m6-aq005dx Keyboard Replacement: 4 단계, 이미지 3/3
    • Use the Phillips #00 screw driver head to remove the following screws that secure the motherboard to the top cover:
    • Four 4.6mm screws;
    • Two 3.3 mm screws.
    • Use the Phillips #0 screw driver head to remove the one 4.5mm screw that secure the system board to the top cover.
    • Use the iFixit plastic prying tool to disconnect the seven marked data cables linked to the system board.
    • Lift the motherboard to remove it from the top cover.
  5. HP Envy x360 m6-aq005dx Keyboard Replacement: 5 단계, 이미지 1/2 HP Envy x360 m6-aq005dx Keyboard Replacement: 5 단계, 이미지 2/2
    • Use the Phillips #00 screw driver head to remove the three 4.6mm screws that secure the hard drive to the top cover.
    • Remove the hard drive.
  6. HP Envy x360 m6-aq005dx Keyboard Replacement: 6 단계, 이미지 1/3 HP Envy x360 m6-aq005dx Keyboard Replacement: 6 단계, 이미지 2/3 HP Envy x360 m6-aq005dx Keyboard Replacement: 6 단계, 이미지 3/3
    • Use the Phillips #0 screw driver head to remove the six 4.5mm screws that secure the display assembly to the keyboard/ top cover.
    • Use the Phillips #00 screw driver head to remove the three 3.3mm screw that secure the connector board to the keyboard/top cover then remove the connector board.
    • Replace the keyboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Bo Sun
회원 가입일: 10/08/16
183 평판
안내서 1개 작성함
IUPUI, Team S4-G4, Wilson Fall 2019 IUPUI, Team S4-G4, Wilson Fall 2019 회원
IUPUI-WILSON-F19S4G4
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 22
전체 시간: 1,182
