주요 콘텐츠로 건너뛰기
HP Envy x360 m6-aq005dx Motherboard Replacement
필요한 것
  1. HP Envy x360 m6-aq005dx Motherboard Replacement, Back Panel: 1 단계, 이미지 1/2 HP Envy x360 m6-aq005dx Motherboard Replacement, Back Panel: 1 단계, 이미지 2/2
    • Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top.
  2. HP Envy x360 m6-aq005dx Motherboard Replacement: 2 단계, 이미지 1/3 HP Envy x360 m6-aq005dx Motherboard Replacement: 2 단계, 이미지 2/3 HP Envy x360 m6-aq005dx Motherboard Replacement: 2 단계, 이미지 3/3
    • Use a Torx T5 screwdriver to remove the six 5.1 mm screws.
    • Use a JIS #1 screwdriver to remove the two 7.2mm screws.
  3. HP Envy x360 m6-aq005dx Motherboard Replacement: 3 단계, 이미지 1/1
    • Use a plastic opening tool to pry open the case. Go slowly around the edge. You will hear popping noises, such are due to popping open the small joints that keep the cover attached.
  4. HP Envy x360 m6-aq005dx Motherboard Replacement, Battery: 4 단계, 이미지 1/2 HP Envy x360 m6-aq005dx Motherboard Replacement, Battery: 4 단계, 이미지 2/2
    • Use a JIS #1 screwdriver to remove the six 4.7 mm screws.
  5. HP Envy x360 m6-aq005dx Motherboard Replacement: 5 단계, 이미지 1/1
    • Battery might cause a small electric shock.
    • Use tweezers to disconnect the battery from the motherboard.
  6. HP Envy x360 m6-aq005dx Motherboard Replacement, Fan: 6 단계, 이미지 1/1
    • Use the plastic opening tool to disconnect the power cable from the fan.
  7. HP Envy x360 m6-aq005dx Motherboard Replacement: 7 단계, 이미지 1/2 HP Envy x360 m6-aq005dx Motherboard Replacement: 7 단계, 이미지 2/2
    • Use your fingers to lightly pull the cable and disconnect it from the motherboard.
  8. HP Envy x360 m6-aq005dx Motherboard Replacement: 8 단계, 이미지 1/3 HP Envy x360 m6-aq005dx Motherboard Replacement: 8 단계, 이미지 2/3 HP Envy x360 m6-aq005dx Motherboard Replacement: 8 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to loosen the four 6.5 mm screws.
    • Do not fully remove the screws, just enough to be unattached from the motherboard.
    • Use a JIS #1 screwdriver to remove the two 7.7 mm screws.
  9. HP Envy x360 m6-aq005dx Motherboard Replacement, Motherboard: 9 단계, 이미지 1/2 HP Envy x360 m6-aq005dx Motherboard Replacement, Motherboard: 9 단계, 이미지 2/2
    • Use a JIS #1 screwdriver to remove the 4.7mm screws from the indicated positions.
    • Use the JIS #1 screwdriver to remove the 7.7mm screws from the indicated positions.
    • Use the JIS #1 screwdriver to remove the 4.4mm screws from the indicated positions.
  10. HP Envy x360 m6-aq005dx Motherboard Replacement: 10 단계, 이미지 1/1
    • Using your hand, lift the screen hinge located in the top left corner. This will allow for easier removal of the motherboard.
  11. HP Envy x360 m6-aq005dx Motherboard Replacement: 11 단계, 이미지 1/3 HP Envy x360 m6-aq005dx Motherboard Replacement: 11 단계, 이미지 2/3 HP Envy x360 m6-aq005dx Motherboard Replacement: 11 단계, 이미지 3/3
    • Flip the indicated colored latches with iFixit Opening Tools, then use tweezers to release the cables attached to the motherboard by gently pulling backward.
    • Use the pointed tweezer to release the plug-in connectors my gently gripping the plug and pulling backwards.
  12. HP Envy x360 m6-aq005dx Motherboard Replacement: 12 단계, 이미지 1/3 HP Envy x360 m6-aq005dx Motherboard Replacement: 12 단계, 이미지 2/3 HP Envy x360 m6-aq005dx Motherboard Replacement: 12 단계, 이미지 3/3
    • Using your hand, lift and pull the motherboard from inside your computer.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Bradley Braganza
회원 가입일: 10/31/18
235 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G1, Harley Fall 2018 IUPUI, Team S1-G1, Harley Fall 2018 회원
IUPUI-HARLEY-F18S1G1
2 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 7
전체 시간: 959
