소개
The motherboard is the main circuit board found in a laptop. It manages the communication between crucial electronic components that allow your computer to function. This guide will describe how to remove and replace the motherboard for HP Envy x360m6-aq005dx
필요한 것
Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top.
Use a JIS #1 screwdriver to remove the 4.7mm screws from the indicated positions.
Use the JIS #1 screwdriver to remove the 7.7mm screws from the indicated positions.
Use the JIS #1 screwdriver to remove the 4.4mm screws from the indicated positions.
Flip the indicated colored latches with iFixit Opening Tools, then use tweezers to release the cables attached to the motherboard by gently pulling backward.
Use the pointed tweezer to release the plug-in connectors my gently gripping the plug and pulling backwards.
다른 한 분이 해당 안내서를 완성하였습니다.
