주요 콘텐츠로 건너뛰기
HP Envy x360 m6-aq005dx Touchpad Replacement
필요한 것
  1. HP Envy x360 m6-aq005dx Touchpad Replacement, Back Panel: 1 단계, 이미지 1/2 HP Envy x360 m6-aq005dx Touchpad Replacement, Back Panel: 1 단계, 이미지 2/2
    • Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top.
  2. HP Envy x360 m6-aq005dx Touchpad Replacement: 2 단계, 이미지 1/3 HP Envy x360 m6-aq005dx Touchpad Replacement: 2 단계, 이미지 2/3 HP Envy x360 m6-aq005dx Touchpad Replacement: 2 단계, 이미지 3/3
    • Use a Torx T5 screwdriver to remove the six 5.1 mm screws.
    • Use a JIS #1 screwdriver to remove the two 7.2mm screws.
  3. HP Envy x360 m6-aq005dx Touchpad Replacement: 3 단계, 이미지 1/1
    • Use a plastic opening tool to pry open the case. Go slowly around the edge. You will hear popping noises, such are due to popping open the small joints that keep the cover attached.
  4. HP Envy x360 m6-aq005dx Touchpad Replacement, Battery: 4 단계, 이미지 1/2 HP Envy x360 m6-aq005dx Touchpad Replacement, Battery: 4 단계, 이미지 2/2
    • Use a JIS #1 screwdriver to remove the six 4.7 mm screws.
  5. HP Envy x360 m6-aq005dx Touchpad Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Battery might cause a small electric shock.
    • Use tweezers to disconnect the battery from the motherboard.
  6. HP Envy x360 m6-aq005dx Touchpad Replacement, Touchpad: 6 단계, 이미지 1/1
    • Carefully, pull back the locking clip of the connector using a plastic opening tool and disconnect cable.
  7. HP Envy x360 m6-aq005dx Touchpad Replacement: 7 단계, 이미지 1/2 HP Envy x360 m6-aq005dx Touchpad Replacement: 7 단계, 이미지 2/2
    • The red square contains two screws side by side.
    • Using a PH0 bit remove the 7 (2.8 mm) screws securing the touchpad to the device.
  8. HP Envy x360 m6-aq005dx Touchpad Replacement: 8 단계, 이미지 1/2 HP Envy x360 m6-aq005dx Touchpad Replacement: 8 단계, 이미지 2/2
    • Keep the ribbon cable from interfering with touchpad removal.
    • Use a plastic opening tool to pry up the touchpad.
    • Gently, pull out the touchpad from device.
결론
Darrin Smiley
회원 가입일: 10/10/17
261 평판
안내서 2개 작성하였습니다
USF Tampa, Team S13-G17, Cagle Fall 2017 USF Tampa, Team S13-G17, Cagle Fall 2017 회원
USFT-CAGLE-F17S13G17
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 1,204
