주요 콘텐츠로 건너뛰기
HP Envy x360 m6-aq103dx Battery Replacement
필요한 것
  1. HP Envy x360 m6-aq103dx Battery Replacement, Bottom Cover: 1 단계, 이미지 1/3 HP Envy x360 m6-aq103dx Battery Replacement, Bottom Cover: 1 단계, 이미지 2/3 HP Envy x360 m6-aq103dx Battery Replacement, Bottom Cover: 1 단계, 이미지 3/3
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx Battery Replacement: 2 단계, 이미지 1/1
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx Battery Replacement: 3 단계, 이미지 1/1
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx Battery Replacement: 4 단계, 이미지 1/3 HP Envy x360 m6-aq103dx Battery Replacement: 4 단계, 이미지 2/3 HP Envy x360 m6-aq103dx Battery Replacement: 4 단계, 이미지 3/3
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
  5. HP Envy x360 m6-aq103dx Battery Replacement, Battery: 5 단계, 이미지 1/2 HP Envy x360 m6-aq103dx Battery Replacement, Battery: 5 단계, 이미지 2/2
    • Use the Phillips Head 1 Screwdriver to remove the six 4 mm screws.
  6. HP Envy x360 m6-aq103dx Battery Replacement: 6 단계, 이미지 1/3 HP Envy x360 m6-aq103dx Battery Replacement: 6 단계, 이미지 2/3 HP Envy x360 m6-aq103dx Battery Replacement: 6 단계, 이미지 3/3
    • Disconnect the battery port from the motherboard by gently lifting it on both sides with the plastic opening tool.
    • Lift up the port with the tool.
  7. HP Envy x360 m6-aq103dx Battery Replacement: 7 단계, 이미지 1/3 HP Envy x360 m6-aq103dx Battery Replacement: 7 단계, 이미지 2/3 HP Envy x360 m6-aq103dx Battery Replacement: 7 단계, 이미지 3/3
    • Lift the battery out of the laptop with your hands.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Sarah Samora
회원 가입일: 10/02/17
777 평판
안내서 3개 작성하였습니다
Cal Poly, Team S4-G3, Livingston Fall 2017 Cal Poly, Team S4-G3, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S4G3
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 34
전체 시간: 7,400
