주요 콘텐츠로 건너뛰기
HP Envy x360 m6-aq103dx CPU Fan Replacement
필요한 것
  1. HP Envy x360 m6-aq103dx CPU Fan Replacement, Bottom Cover: 1 단계, 이미지 3개 중 1개 HP Envy x360 m6-aq103dx CPU Fan Replacement, Bottom Cover: 1 단계, 이미지 3개 중 2개 HP Envy x360 m6-aq103dx CPU Fan Replacement, Bottom Cover: 1 단계, 이미지 3개 중 3개
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx CPU Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx CPU Fan Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx CPU Fan Replacement: 4 단계, 이미지 3개 중 1개 HP Envy x360 m6-aq103dx CPU Fan Replacement: 4 단계, 이미지 3개 중 2개 HP Envy x360 m6-aq103dx CPU Fan Replacement: 4 단계, 이미지 3개 중 3개
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
  5. HP Envy x360 m6-aq103dx CPU Fan Replacement, CPU Fan: 5 단계, 이미지 3개 중 1개 HP Envy x360 m6-aq103dx CPU Fan Replacement, CPU Fan: 5 단계, 이미지 3개 중 2개 HP Envy x360 m6-aq103dx CPU Fan Replacement, CPU Fan: 5 단계, 이미지 3개 중 3개
    • Put on the anti-static wristband first
    • Disconnect the port of the fan by flipping the black tab with the small blue plastic opening tool.
    • Remove the cable from the connector.
  6. HP Envy x360 m6-aq103dx CPU Fan Replacement: 6 단계, 이미지 3개 중 1개 HP Envy x360 m6-aq103dx CPU Fan Replacement: 6 단계, 이미지 3개 중 2개 HP Envy x360 m6-aq103dx CPU Fan Replacement: 6 단계, 이미지 3개 중 3개
    • Peel back a little bit of the grey tape connected to the round cable with the big blue opening tool.
    • Using your fingers, peel the tape off of the body of the computer.
    • Peel slowly to avoid separating the adhesive.
  7. HP Envy x360 m6-aq103dx CPU Fan Replacement: 7 단계, 이미지 2개 중 1개 HP Envy x360 m6-aq103dx CPU Fan Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the black cable from the fan by unclicking it from the plastic body of the fan with your fingers and move it out of the area.
    • There will be clicking sounds when the black cable is removed.
  8. HP Envy x360 m6-aq103dx CPU Fan Replacement: 8 단계, 이미지 3개 중 1개 HP Envy x360 m6-aq103dx CPU Fan Replacement: 8 단계, 이미지 3개 중 2개 HP Envy x360 m6-aq103dx CPU Fan Replacement: 8 단계, 이미지 3개 중 3개
    • Disconnect the port with the red yellow and blue wires by dislodging the wires with your fingers.
  9. HP Envy x360 m6-aq103dx CPU Fan Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the two 4.5mm Phillips #1 screws.
  10. HP Envy x360 m6-aq103dx CPU Fan Replacement: 10 단계, 이미지 1개 중 1개
    • Loosen the four black screws by the curved heat sink with a Phillips head 1 screwdriver.
    • These screws do not come off.
  11. HP Envy x360 m6-aq103dx CPU Fan Replacement: 11 단계, 이미지 3개 중 1개 HP Envy x360 m6-aq103dx CPU Fan Replacement: 11 단계, 이미지 3개 중 2개 HP Envy x360 m6-aq103dx CPU Fan Replacement: 11 단계, 이미지 3개 중 3개
    • Lift the CPU fan out with your hand.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jordan Eremeyeff
회원 가입일: 10/01/17
612 평판
안내서 3개를 작성함
Cal Poly, Team S4-G3, Livingston Fall 2017 Cal Poly, Team S4-G3, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S4G3
4 회원들
안내서 9개를 작성함
3가이드 댓글
Step 5-7 can be bypassed I didn’t need to do it
diego.montenegro23 - 답글
My first home repair so far. Really easy to follow guide. Great job!
Caleb Robinson - 답글
Purchased tools and did the steps, no issues. worth the tools to use later. Worked in iT anyways.
Roy Rodgers - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 23
전체 시간: 4,826
