주요 콘텐츠로 건너뛰기
HP Envy x360 m6-aq103dx Hard drive Replacement
필요한 것
  1. HP Envy x360 m6-aq103dx Hard drive Replacement, Bottom Cover: 1 단계, 이미지 1/3 HP Envy x360 m6-aq103dx Hard drive Replacement, Bottom Cover: 1 단계, 이미지 2/3 HP Envy x360 m6-aq103dx Hard drive Replacement, Bottom Cover: 1 단계, 이미지 3/3
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx Hard drive Replacement: 2 단계, 이미지 1/1
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx Hard drive Replacement: 3 단계, 이미지 1/1
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx Hard drive Replacement: 4 단계, 이미지 1/3 HP Envy x360 m6-aq103dx Hard drive Replacement: 4 단계, 이미지 2/3 HP Envy x360 m6-aq103dx Hard drive Replacement: 4 단계, 이미지 3/3
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
  5. HP Envy x360 m6-aq103dx Hard drive Replacement, Hard Drive: 5 단계, 이미지 1/3 HP Envy x360 m6-aq103dx Hard drive Replacement, Hard Drive: 5 단계, 이미지 2/3 HP Envy x360 m6-aq103dx Hard drive Replacement, Hard Drive: 5 단계, 이미지 3/3
    • Disconnect the ribbon cable with the purple tag by flipping the black tab with the plastic opening tool.
    • Disconnect the ribbon cable by gently pulling it away from the connector with your fingers.
  6. HP Envy x360 m6-aq103dx Hard drive Replacement: 6 단계, 이미지 1/3 HP Envy x360 m6-aq103dx Hard drive Replacement: 6 단계, 이미지 2/3 HP Envy x360 m6-aq103dx Hard drive Replacement: 6 단계, 이미지 3/3
    • Remove the two Phillips head screws (5 mm) using the Phillip's head #1 screwdriver.
    • Use your hands to lift the hard drive up and remove it.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Jordan Eremeyeff
회원 가입일: 10/01/17
597 평판
안내서 3개 작성하였습니다
Cal Poly, Team S4-G3, Livingston Fall 2017 Cal Poly, Team S4-G3, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S4G3
4 회원들
안내서 9개 작성하였습니다
댓글 한 개
Great guide. Only thing i did different was not removing the ribbon cable. It’s not necessary. Just unscrew the hard drive enclosure and you’ll have plenty of room to disconnect the sata connector plugged in to the drive.
Ron H - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 28
전체 시간: 7,126
