주요 콘텐츠로 건너뛰기
HP Envy x360 m6-aq105dx Audio Jack Replacement
필요한 것
  1. HP Envy x360 m6-aq105dx Audio Jack Replacement, Back Cover: 1 단계, 이미지 1/1
    • Ground yourself by touching a metal object or surface. This prevents electrical damage to other components in the laptop.
    • Remove the two 7.8 mm screws using the Phillips #0 screwdriver.
    • Remove the six 5.2 mm screws using the Torx T5 screwdriver.
  2. HP Envy x360 m6-aq105dx Audio Jack Replacement: 2 단계, 이미지 1/1
    • Light to moderate force is required to remove the back cover.
    • Insert the Jimmy in between the frame of the laptop and the removable back cover and remove the back cover from the device.
  3. HP Envy x360 m6-aq105dx Audio Jack Replacement, Audio Jack: 3 단계, 이미지 1/1
    • Attach the grounding bracelet's clip to the frame of the laptop, then put on the grounding bracelet.
    • Remove the two 4.6 mm screws using the Phillips #0 screwdriver.
    • Remove the one 4.4mm screw using the Phillips #0 screwdriver.
    • Remove the one 2.8mm screws securing the audio jack/power button board using the Phillips #0 screwdriver.
  4. HP Envy x360 m6-aq105dx Audio Jack Replacement: 4 단계, 이미지 1/2 HP Envy x360 m6-aq105dx Audio Jack Replacement: 4 단계, 이미지 2/2
    • Place the blue plastic opening tool on top of the blue data ribbon and under the connector. Lift up on the blue plastic opening tool to open the connector.
    • Remove the blue data ribbon from the audio board.
  5. HP Envy x360 m6-aq105dx Audio Jack Replacement: 5 단계, 이미지 1/2 HP Envy x360 m6-aq105dx Audio Jack Replacement: 5 단계, 이미지 2/2
    • Remove the audio jack motherboard from the computer.
결론
Cory Smith
회원 가입일: 01/16/20
389 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 313
