주요 콘텐츠로 건너뛰기
HP Envy x360 m6-aq105dx RAM Replacement
필요한 것
  1. HP Envy x360 m6-aq105dx RAM Replacement, Back Cover: 1 단계, 이미지 1/1
    • Ground yourself by touching a metal object or surface. This prevents electrical damage to other components in the laptop.
    • Remove the two 7.8 mm screws using the Phillips #0 screwdriver.
    • Remove the six 5.2 mm screws using the Torx T5 screwdriver.
  2. HP Envy x360 m6-aq105dx RAM Replacement: 2 단계, 이미지 1/1
    • Light to moderate force is required to remove the back cover.
    • Insert the Jimmy in between the frame of the laptop and the removable back cover and remove the back cover from the device.
  3. HP Envy x360 m6-aq105dx RAM Replacement, RAM: 3 단계, 이미지 1/1
    • Attach the grounding bracelet's clip to the frame of the laptop then put on the grounding bracelet.
    • Lift up the RAM cover panel and remove it from the device.
  4. HP Envy x360 m6-aq105dx RAM Replacement: 4 단계, 이미지 1/2 HP Envy x360 m6-aq105dx RAM Replacement: 4 단계, 이미지 2/2
    • Pull away the levers away from each other to disconnect the RAM stick. Repeat this step for any subsequent sticks of RAM.
결론
Cory Smith
회원 가입일: 01/16/20
389 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 280
