주요 콘텐츠로 건너뛰기
HP Envy x360 m6-w103dx Hard Drive Replacement
필요한 것
  1. HP Envy x360 m6-w103dx Hard Drive Replacement, Keyboard: 1 단계, 이미지 1/2 HP Envy x360 m6-w103dx Hard Drive Replacement, Keyboard: 1 단계, 이미지 2/2
    • Before you begin, be sure to power off your laptop.
    • Using an opening pick, remove the 4 rubber feet and 4 screw covers.
  2. HP Envy x360 m6-w103dx Hard Drive Replacement: 2 단계, 이미지 1/2 HP Envy x360 m6-w103dx Hard Drive Replacement: 2 단계, 이미지 2/2
    • Unscrew the twelve 6 mm screws from the bottom of the laptop using a Phillips #0 screwdriver.
  3. HP Envy x360 m6-w103dx Hard Drive Replacement: 3 단계, 이미지 1/3 HP Envy x360 m6-w103dx Hard Drive Replacement: 3 단계, 이미지 2/3 HP Envy x360 m6-w103dx Hard Drive Replacement: 3 단계, 이미지 3/3
    • Open the laptop carefully, with the keyboard face up.
    • Pry around the outside of the keyboard with the plastic opening tool until the keyboard can be lifted slightly.
    • When lifting the keyboard do not pull too hard. There are cables that must be disconnected before the keyboard can be removed.
  4. HP Envy x360 m6-w103dx Hard Drive Replacement: 4 단계, 이미지 1/3 HP Envy x360 m6-w103dx Hard Drive Replacement: 4 단계, 이미지 2/3 HP Envy x360 m6-w103dx Hard Drive Replacement: 4 단계, 이미지 3/3
    • Lift the keyboard until you can see the cables connected to the motherboard.
    • Gently lift the tab on each ZIF connector that connects each cable to the motherboard using a spudger. Once each tab is flipped up, the corresponding ribbon cable will come out easily.
    • Detach the keyboard.
  5. HP Envy x360 m6-w103dx Hard Drive Replacement, Hard Drive: 5 단계, 이미지 1/2 HP Envy x360 m6-w103dx Hard Drive Replacement, Hard Drive: 5 단계, 이미지 2/2
    • Disconnect the connector by pushing up the white tab directly above the hard drive.
    • Gently lift the connector to disconnect.
  6. HP Envy x360 m6-w103dx Hard Drive Replacement: 6 단계, 이미지 1/3 HP Envy x360 m6-w103dx Hard Drive Replacement: 6 단계, 이미지 2/3 HP Envy x360 m6-w103dx Hard Drive Replacement: 6 단계, 이미지 3/3
    • Using the plastic opening tool, gently lift the hard drive.
    • Remove the hard drive by lifting it from the other components.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Steven Ngo
회원 가입일: 10/10/19
927 평판
안내서 7개 작성하였습니다
Cal Poly, Team S12-G2, Regan Fall 2019 Cal Poly, Team S12-G2, Regan Fall 2019 회원
CPSU-REGAN-F19S12G2
4 회원들
안내서 23개 작성하였습니다
댓글 2개
Does this laptop have m2 slot? Or sata?
Dhakichiki Dhakichiki - 답글
For anyone else wondering: This laptop (m6-w103dx) does not have an m2 slot. It only has a 2.5" SATA bay. I replaced the built-in HDD (Toshiba) with a Crucial MX500 and it works perfectly. Pair this guide with the RAM upgrade one by the same author (it supports up to 16 GB, two 8 GB sticks) and you have yourself a much faster laptop.
Aleksandr - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 13
30일 전: 48
전체 시간: 2,064
