주요 콘텐츠로 건너뛰기
HP Envy x360 m6-w103dx Keyboard Replacement
필요한 것
  1. HP Envy x360 m6-w103dx Keyboard Replacement, Keyboard: 1 단계, 이미지 2개 중 1개 HP Envy x360 m6-w103dx Keyboard Replacement, Keyboard: 1 단계, 이미지 2개 중 2개
    • Before you begin, be sure to power off your laptop.
    • Using an opening pick, remove the 4 rubber feet and 4 screw covers.
  2. HP Envy x360 m6-w103dx Keyboard Replacement: 2 단계, 이미지 2개 중 1개 HP Envy x360 m6-w103dx Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Unscrew the twelve 6 mm screws from the bottom of the laptop using a Phillips #0 screwdriver.
  3. HP Envy x360 m6-w103dx Keyboard Replacement: 3 단계, 이미지 3개 중 1개 HP Envy x360 m6-w103dx Keyboard Replacement: 3 단계, 이미지 3개 중 2개 HP Envy x360 m6-w103dx Keyboard Replacement: 3 단계, 이미지 3개 중 3개
    • Open the laptop carefully, with the keyboard face up.
    • Pry around the outside of the keyboard with the plastic opening tool until the keyboard can be lifted slightly.
    • When lifting the keyboard do not pull too hard. There are cables that must be disconnected before the keyboard can be removed.
  4. HP Envy x360 m6-w103dx Keyboard Replacement: 4 단계, 이미지 3개 중 1개 HP Envy x360 m6-w103dx Keyboard Replacement: 4 단계, 이미지 3개 중 2개 HP Envy x360 m6-w103dx Keyboard Replacement: 4 단계, 이미지 3개 중 3개
    • Lift the keyboard until you can see the cables connected to the motherboard.
    • Gently lift the tab on each ZIF connector that connects each cable to the motherboard using a spudger. Once each tab is flipped up, the corresponding ribbon cable will come out easily.
    • Detach the keyboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Steven Ngo
회원 가입일: 10/10/19
963 평판
안내서 7개를 작성함
Cal Poly, Team S12-G2, Regan Fall 2019 Cal Poly, Team S12-G2, Regan Fall 2019 회원
CPSU-REGAN-F19S12G2
4 회원들
안내서 23개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 13
지난 30일: 60
전체 시간: 5,268
