주요 콘텐츠로 건너뛰기
HP Envy x360 m6-w103dx Motherboard Replacement
필요한 것
  1. HP Envy x360 m6-w103dx Motherboard Replacement, Keyboard: 1 단계, 이미지 2개 중 1개 HP Envy x360 m6-w103dx Motherboard Replacement, Keyboard: 1 단계, 이미지 2개 중 2개
    • Before you begin, be sure to power off your laptop.
    • Using an opening pick, remove the 4 rubber feet and 4 screw covers.
  2. HP Envy x360 m6-w103dx Motherboard Replacement: 2 단계, 이미지 2개 중 1개 HP Envy x360 m6-w103dx Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Unscrew the twelve 6 mm screws from the bottom of the laptop using a Phillips #0 screwdriver.
  3. HP Envy x360 m6-w103dx Motherboard Replacement: 3 단계, 이미지 3개 중 1개 HP Envy x360 m6-w103dx Motherboard Replacement: 3 단계, 이미지 3개 중 2개 HP Envy x360 m6-w103dx Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • Open the laptop carefully, with the keyboard face up.
    • Pry around the outside of the keyboard with the plastic opening tool until the keyboard can be lifted slightly.
    • When lifting the keyboard do not pull too hard. There are cables that must be disconnected before the keyboard can be removed.
  4. HP Envy x360 m6-w103dx Motherboard Replacement: 4 단계, 이미지 3개 중 1개 HP Envy x360 m6-w103dx Motherboard Replacement: 4 단계, 이미지 3개 중 2개 HP Envy x360 m6-w103dx Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    • Lift the keyboard until you can see the cables connected to the motherboard.
    • Gently lift the tab on each ZIF connector that connects each cable to the motherboard using a spudger. Once each tab is flipped up, the corresponding ribbon cable will come out easily.
    • Detach the keyboard.
  5. HP Envy x360 m6-w103dx Motherboard Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
    • Disconnect the pin head battery connection to remove power from the motherboard.
    • Unscrew the five 4mm screws holding the motherboard in place using a #0 Phillips screwdriver.
    • It's possible the positions of the screws will be different on your board. If the motherboard resists lifting, double-check that all screws have been removed.
  6. HP Envy x360 m6-w103dx Motherboard Replacement: 6 단계, 이미지 3개 중 1개 HP Envy x360 m6-w103dx Motherboard Replacement: 6 단계, 이미지 3개 중 2개 HP Envy x360 m6-w103dx Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the five flat ribbon cables by gently lifting the head of the cable up and back.
    • Remove the two remaining multicolored ribbon cables by pulling the white plastic head backwards.
    • Do not pull directly on the wires.
    • If the head of the multicolored ribbon cable doesn't come out, try gently wiggling it side to side as you pull.
  7. HP Envy x360 m6-w103dx Motherboard Replacement: 7 단계, 이미지 3개 중 1개 HP Envy x360 m6-w103dx Motherboard Replacement: 7 단계, 이미지 3개 중 2개 HP Envy x360 m6-w103dx Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    • Lift the motherboard up from the left side at a shallow angle.
    • Gently pull the motherboard to the left and gently wiggle it side to side until the ports on the right side of the board detach from the case.
    • Ensure the laptop is well supported, as the motherboard is a heavy component and removing it may make the laptop off-balance.
결론
작성자
4다른 기여자 명과 함께
Steven Ngo
회원 가입일: 10/10/19
963 평판
안내서 7개를 작성함
Cal Poly, Team S12-G2, Regan Fall 2019 Cal Poly, Team S12-G2, Regan Fall 2019 회원
CPSU-REGAN-F19S12G2
4 회원들
안내서 23개를 작성함
2가이드 댓글
Can I Change the graphics card only?
Is there a way to fix only the graphics card?
Frank - 답글
I wonder if it’s possible to solder on an M.2 header on that SSD1 spot on the board.
Isaac Zachary - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 28
전체 시간: 2,082
