주요 콘텐츠로 건너뛰기
HP Envy x360 m6-w103dx Speakers Replacement
필요한 것
  1. HP Envy x360 m6-w103dx Speakers Replacement, Keyboard: 1 단계, 이미지 1/2 HP Envy x360 m6-w103dx Speakers Replacement, Keyboard: 1 단계, 이미지 2/2
    • Before you begin, be sure to power off your laptop.
    • Using an opening pick, remove the 4 rubber feet and 4 screw covers.
  2. HP Envy x360 m6-w103dx Speakers Replacement: 2 단계, 이미지 1/2 HP Envy x360 m6-w103dx Speakers Replacement: 2 단계, 이미지 2/2
    • Unscrew the twelve 6 mm screws from the bottom of the laptop using a Phillips #0 screwdriver.
  3. HP Envy x360 m6-w103dx Speakers Replacement: 3 단계, 이미지 1/3 HP Envy x360 m6-w103dx Speakers Replacement: 3 단계, 이미지 2/3 HP Envy x360 m6-w103dx Speakers Replacement: 3 단계, 이미지 3/3
    • Open the laptop carefully, with the keyboard face up.
    • Pry around the outside of the keyboard with the plastic opening tool until the keyboard can be lifted slightly.
    • When lifting the keyboard do not pull too hard. There are cables that must be disconnected before the keyboard can be removed.
  4. HP Envy x360 m6-w103dx Speakers Replacement: 4 단계, 이미지 1/3 HP Envy x360 m6-w103dx Speakers Replacement: 4 단계, 이미지 2/3 HP Envy x360 m6-w103dx Speakers Replacement: 4 단계, 이미지 3/3
    • Lift the keyboard until you can see the cables connected to the motherboard.
    • Gently lift the tab on each ZIF connector that connects each cable to the motherboard using a spudger. Once each tab is flipped up, the corresponding ribbon cable will come out easily.
    • Detach the keyboard.
  5. HP Envy x360 m6-w103dx Speakers Replacement, Speakers: 5 단계, 이미지 1/1
    • Disconnect the connector on the left speaker by gently pulling on each side of the connector.
    • Do not pull directly on the wires.
  6. HP Envy x360 m6-w103dx Speakers Replacement: 6 단계, 이미지 1/2 HP Envy x360 m6-w103dx Speakers Replacement: 6 단계, 이미지 2/2
    • Unscrew the three 6mm screws using a #00 Phillips screwdriver, one on the right speaker and two on the left speaker.
  7. HP Envy x360 m6-w103dx Speakers Replacement: 7 단계, 이미지 1/3 HP Envy x360 m6-w103dx Speakers Replacement: 7 단계, 이미지 2/3 HP Envy x360 m6-w103dx Speakers Replacement: 7 단계, 이미지 3/3
    • Remove each speaker one at a time.
    • Carefully remove the wire connecting the two speakers, which is tucked under small plastic hooks on the bottom edge of the device.
결론
Steven Ngo
회원 가입일: 10/10/19
927 평판
안내서 7개 작성하였습니다
Cal Poly, Team S12-G2, Regan Fall 2019 Cal Poly, Team S12-G2, Regan Fall 2019 회원
CPSU-REGAN-F19S12G2
4 회원들
안내서 23개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 10
30일 전: 12
전체 시간: 617
