주요 콘텐츠로 건너뛰기
HP Envy x360 m6-w105dx Wi-Fi Card Replacement
필요한 것
  1. HP Envy x360 m6-w105dx Wi-Fi Card Replacement, Keyboard: 1 단계, 이미지 1/3 HP Envy x360 m6-w105dx Wi-Fi Card Replacement, Keyboard: 1 단계, 이미지 2/3 HP Envy x360 m6-w105dx Wi-Fi Card Replacement, Keyboard: 1 단계, 이미지 3/3
    • Make sure the laptop is powered off and disconnected from any outlets.
    • Use the opening pick to lift up the eight rubber grips on the underside of the device.
    • With the #1 Phillips screwdriver, remove the twelve 6mm screws from the back case.
  2. HP Envy x360 m6-w105dx Wi-Fi Card Replacement: 2 단계, 이미지 1/2 HP Envy x360 m6-w105dx Wi-Fi Card Replacement: 2 단계, 이미지 2/2
    • Open the laptop and turn to the keyboard.
    • Gently insert an opening pick into the edge of the keyboard panel, and slide around the keyboard lining until the clips have all been disengaged.
    • Lift the keyboard panel from the bottom and carefully start to lift up.
    • There are ribbon cables still connected on the under side of the the keyboard. Do not pull the keyboard away from the device.
  3. HP Envy x360 m6-w105dx Wi-Fi Card Replacement: 3 단계, 이미지 1/2 HP Envy x360 m6-w105dx Wi-Fi Card Replacement: 3 단계, 이미지 2/2
    • Gently lift the keyboard up from the bottom.
    • Carefully open the locking flap of the three ZIF connectors and detach the three ribbon cables from the motherboard using your fingers.
    • Do not remove the ZIF connectors by pulling on the wires, instead detach them by gently flipping up the plastic tabs located at the ends of the wiring.
    • Fully remove the keyboard from the laptop and install your new keyboard.
  4. HP Envy x360 m6-w105dx Wi-Fi Card Replacement, Wi-Fi Card: 4 단계, 이미지 1/3 HP Envy x360 m6-w105dx Wi-Fi Card Replacement, Wi-Fi Card: 4 단계, 이미지 2/3 HP Envy x360 m6-w105dx Wi-Fi Card Replacement, Wi-Fi Card: 4 단계, 이미지 3/3
    • Take the #1 Phillips screwdriver and unscrew the 0.4mm silver screw holding down the wireless card.
  5. HP Envy x360 m6-w105dx Wi-Fi Card Replacement: 5 단계, 이미지 1/3 HP Envy x360 m6-w105dx Wi-Fi Card Replacement: 5 단계, 이미지 2/3 HP Envy x360 m6-w105dx Wi-Fi Card Replacement: 5 단계, 이미지 3/3
    • Push the chip up with the pick and forward to remove it from the port it is sitting in.
    • Take the precision tweezers and pull the two snap wires off of the chip.
    • The wires have snap connectors for easy replacement and removal.
    • Remove the Wi-Fi Card from the device.
결론
Dalton Hancock
회원 가입일: 01/24/20
417 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 12
전체 시간: 1,185
