주요 콘텐츠로 건너뛰기
HP Flyer Red Battery Replacement
  1. HP Flyer Red Battery Replacement, Battery: 1 단계, 이미지 1/2 HP Flyer Red Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure your laptop is powered off.
    • With laptop closed flip to look at the underside of the laptop.
  2. HP Flyer Red Battery Replacement: 2 단계, 이미지 1/1
    • On the underside of the laptop towards the hinge for the screen there are two rectangular slide switches located inside of rectangular tracks.
  3. HP Flyer Red Battery Replacement: 3 단계, 이미지 1/2 HP Flyer Red Battery Replacement: 3 단계, 이미지 2/2
    • The left switch is the battery unlock switch.
    • Inside the rectangular track of this switch there is an image of a closed lock that should be visible. Push this switch to the other end of the track and an image of an open lock should be visible.
  4. HP Flyer Red Battery Replacement: 4 단계, 이미지 1/1
    • Then take and slide the other switch to the other end of its track which will pop out the battery.
    • Grab the battery and pull it out of the slot.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Anthony Ciotti
회원 가입일: 04/07/16
747 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 4-5, Catania Spring 2016 UMass Dartmouth, Team 4-5, Catania Spring 2016 회원
UMASSD-CATANIA-S16S4G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 20
전체 시간: 2,304
