주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Flyer Red Keyboard Replacement
필요한 것
  1. HP Flyer Red Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Flyer Red Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Make sure your laptop is powered off.
    • With laptop closed flip to look at the underside of the laptop.
  2. HP Flyer Red Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • On the underside of the laptop towards the hinge for the screen there are two rectangular slide switches located inside of rectangular tracks.
  3. HP Flyer Red Keyboard Replacement: 3 단계, 이미지 2개 중 1개 HP Flyer Red Keyboard Replacement: 3 단계, 이미지 2개 중 2개
    • The left switch is the battery unlock switch.
    • Inside the rectangular track of this switch there is an image of a closed lock that should be visible. Push this switch to the other end of the track and an image of an open lock should be visible.
  4. HP Flyer Red Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Then take and slide the other switch to the other end of its track which will pop out the battery.
    • Grab the battery and pull it out of the slot.
  5. HP Flyer Red Keyboard Replacement, Keyboard: 5 단계, 이미지 2개 중 1개 HP Flyer Red Keyboard Replacement, Keyboard: 5 단계, 이미지 2개 중 2개
    • Next locate and unscrew the two 4mm Phllips #1 screws with the keyboard symbol located towards the middle and top of the bottom of the laptop.
  6. HP Flyer Red Keyboard Replacement: 6 단계, 이미지 3개 중 1개 HP Flyer Red Keyboard Replacement: 6 단계, 이미지 3개 중 2개 HP Flyer Red Keyboard Replacement: 6 단계, 이미지 3개 중 3개
    • Next turn the laptop over and flip open the screen.
    • Use the plastic opening tool to pry the keyboard upwards from the bottom right hand corner of the keyboard.
    • Use another plastic opening tool with the first plastic opening tool you placed to undo every plastic clasp surrounding the keyboard.
  7. HP Flyer Red Keyboard Replacement: 7 단계, 이미지 3개 중 1개 HP Flyer Red Keyboard Replacement: 7 단계, 이미지 3개 중 2개 HP Flyer Red Keyboard Replacement: 7 단계, 이미지 3개 중 3개
    • Next lift up the keyboard gently and use the plastic opening tool to undo the ribbon wire by unclasping the ZIF (zero insertion force) connector to the laptop.
    • Gently slide the ribbon wire out of its slot.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Anthony Ciotti
회원 가입일: 04/07/16
777 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 44
전체 시간: 2,540
