주요 콘텐츠로 건너뛰기
HP Folio 13t-1000 Heatsink Replacement
필요한 것
  1. HP Folio 13t-1000 Heatsink Replacement, Keyboard: 1 단계, 이미지 1/2 HP Folio 13t-1000 Heatsink Replacement, Keyboard: 1 단계, 이미지 2/2
    • Use an antistatic wrist wrap, or periodically touch unpainted metal to minimize the risk of damaging the laptop by electrostatic shock.
    • Use a PH1 screw head to remove the 16, 6mm screws from the bottom case housing of the laptop.
  2. HP Folio 13t-1000 Heatsink Replacement: 2 단계, 이미지 1/3 HP Folio 13t-1000 Heatsink Replacement: 2 단계, 이미지 2/3 HP Folio 13t-1000 Heatsink Replacement: 2 단계, 이미지 3/3
    • This step requires unlocking the very fragile plastic clips along the frame; take care not to damage them.
    • Slide the spudger with a twisting motion along the entire perimeter of the laptop until the top cover is separated from the frame of the device.
  3. HP Folio 13t-1000 Heatsink Replacement: 3 단계, 이미지 1/1
    • Using the flat portion of the plastic spudger, push the corner of the black surface until the first clip unlocks.
    • The top right corner of the keyboard should now be sticking out slightly.
    • Repeat the same process for the top left corner.
  4. HP Folio 13t-1000 Heatsink Replacement: 4 단계, 이미지 1/2 HP Folio 13t-1000 Heatsink Replacement: 4 단계, 이미지 2/2
    • Slide the keyboard up and towards the screen just enough to separate the keyboard from the top cover.
  5. HP Folio 13t-1000 Heatsink Replacement: 5 단계, 이미지 1/3 HP Folio 13t-1000 Heatsink Replacement: 5 단계, 이미지 2/3 HP Folio 13t-1000 Heatsink Replacement: 5 단계, 이미지 3/3
    • To unlock the clamps connected to the motherboard, use your fingers or insert the pointed edge of the spudger between the first clamp and the cable.
    • Repeat the same process for the second clamp.
  6. HP Folio 13t-1000 Heatsink Replacement: 6 단계, 이미지 1/3 HP Folio 13t-1000 Heatsink Replacement: 6 단계, 이미지 2/3 HP Folio 13t-1000 Heatsink Replacement: 6 단계, 이미지 3/3
    • Remove the keyboard from the laptop.
  7. HP Folio 13t-1000 Heatsink Replacement, Top Hardware Cover: 7 단계, 이미지 1/3 HP Folio 13t-1000 Heatsink Replacement, Top Hardware Cover: 7 단계, 이미지 2/3 HP Folio 13t-1000 Heatsink Replacement, Top Hardware Cover: 7 단계, 이미지 3/3
    • Place your finger between one of the plastic clamps and the cable and apply a slight leveraging force until the clamp pops up.
    • Do the same for the second connection.
  8. HP Folio 13t-1000 Heatsink Replacement: 8 단계, 이미지 1/2 HP Folio 13t-1000 Heatsink Replacement: 8 단계, 이미지 2/2
    • Remove the top hardware cover.
  9. HP Folio 13t-1000 Heatsink Replacement, Heat Sink: 9 단계, 이미지 1/2 HP Folio 13t-1000 Heatsink Replacement, Heat Sink: 9 단계, 이미지 2/2
    • Use a PH1 screw head to take out the four, 2mm screws.
  10. HP Folio 13t-1000 Heatsink Replacement: 10 단계, 이미지 1/3 HP Folio 13t-1000 Heatsink Replacement: 10 단계, 이미지 2/3 HP Folio 13t-1000 Heatsink Replacement: 10 단계, 이미지 3/3
    • Remove the heatsink with you fingers and replace it with a new heatsink.
결론
Cody Badchkam
회원 가입일: 09/28/16
64 평판
안내서 4개 작성하였습니다
USF Tampa, Team 1-2, Cagle Fall 2016 USF Tampa, Team 1-2, Cagle Fall 2016 회원
USFT-CAGLE-F16S1G2
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 223
