소개
Make sure you have completed the keyboard replacement guide and the top cover removal guide.
A defective RAM can cause your laptop's loading speed to deteriorate. This guide will show you how to correctly replace a defective or an outdated RAM for your HP Folio 13t-1000.
필요한 것
Use a PH1 screw head to remove the 16, 6mm screws from the bottom case housing of the laptop.
Place your finger between one of the plastic clamps and the cable and apply a slight leveraging force until the clamp pops up.
Do the same for the second connection.
