주요 콘텐츠로 건너뛰기
HP G60 RAM Replacement
필요한 것
  1. HP G60 RAM Replacement, Battery: 1 단계, 이미지 3개 중 1개 HP G60 RAM Replacement, Battery: 1 단계, 이미지 3개 중 2개 HP G60 RAM Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • First, you should to remove the battery to avoid electric shocks
    • Slide and unlock the battery, then, lift it
  2. HP G60 RAM Replacement, RAM cover: 2 단계, 이미지 3개 중 1개 HP G60 RAM Replacement, RAM cover: 2 단계, 이미지 3개 중 2개 HP G60 RAM Replacement, RAM cover: 2 단계, 이미지 3개 중 3개
    • Remove the two screws with a not too large screwdriver
    • Now lift the cover, the screws are part of the cover
  3. HP G60 RAM Replacement, Eject RAM: 3 단계, 이미지 3개 중 1개 HP G60 RAM Replacement, Eject RAM: 3 단계, 이미지 3개 중 2개 HP G60 RAM Replacement, Eject RAM: 3 단계, 이미지 3개 중 3개
    • Push the little aluminum locks at the top and the bottom of the ram
    • The memory will lift, then pull it
    • Make this with the another RAM slot
  4. HP G60 RAM Replacement, New RAM: 4 단계, 이미지 3개 중 1개 HP G60 RAM Replacement, New RAM: 4 단계, 이미지 3개 중 2개 HP G60 RAM Replacement, New RAM: 4 단계, 이미지 3개 중 3개
    • The new RAM memory should to be insert in a 45 degrees angle
    • Then, push it and the memory will lock by itself
    • Make this with the second memory
  5. HP G60 RAM Replacement, RAM cover (Again): 5 단계, 이미지 3개 중 1개 HP G60 RAM Replacement, RAM cover (Again): 5 단계, 이미지 3개 중 2개 HP G60 RAM Replacement, RAM cover (Again): 5 단계, 이미지 3개 중 3개
    • Insert the cover from right to left, then, screw it
    • If cover is lifted, press it softly and secure it
결승점
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
jimenezser
회원 가입일: 08/29/12
3,899 평판
안내서 4개를 작성함
1가이드 댓글
Thanks for verifying the RAM replacement and that it was as easy as I thought it was, but that made me a bit nervous, being much more comfortable building desktops as large as my or my customer's budget would allow!
Take 'em out, put new ones back in. As a technical writer, I also appreciate that you kept it to the point without creating further questions to complicate that which is not complicated. Thanks again. Will check out some out your other work.
J Brent Masters - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 30
전체 시간: 6,436
