소개
In order for constant shut downs to persist the hard drive will need to be replaced. At times hard drives installed incorrectly could be the issue and in that case it may not be necessary to completely replace rather to reinstall.
The only tools needed is a Positive PH0 screwdriver.
필요한 것
Place the laptop upside down where the headphone and auxiliary jack are facing you.
Once the battery has been removed, locate the 5mm Phillips #0 screws on the bottom right panel.
Remove the 5mm Phillips #0 screws using the Phillips #0 Screwdriver.
Next, remove the panel that was attached to the screws, leaving the hard drive exposed.
