주요 콘텐츠로 건너뛰기
HP G60T-600 CTO CD Player Replacement
필요한 것
  1. HP G60T-600 CTO CD Player Replacement, Battery: 1 단계, 이미지 1/1
    • Failure to remove the battery before performing any replacement guide may result in electric shock.
    • Close your device, then turn it over.
  2. HP G60T-600 CTO CD Player Replacement: 2 단계, 이미지 1/2 HP G60T-600 CTO CD Player Replacement: 2 단계, 이미지 2/2
    • Place your index finger on the ridged tab.
  3. HP G60T-600 CTO CD Player Replacement: 3 단계, 이미지 1/1
    • Apply moderate pressure to the tab and slide it to the right.
    • While the tab is on the right, you should be able to gently slide your battery out of your device.
  4. HP G60T-600 CTO CD Player Replacement, Keyboard: 4 단계, 이미지 1/2 HP G60T-600 CTO CD Player Replacement, Keyboard: 4 단계, 이미지 2/2
    • Unscrew the following 5mm screws with a #0 Phillips screwdriver.
  5. HP G60T-600 CTO CD Player Replacement: 5 단계, 이미지 1/1
    • Turn your laptop over and open it up.
    • Grip your laptop firmly from both sides and use your thumbs to slide the keyboard towards the screen.
  6. HP G60T-600 CTO CD Player Replacement: 6 단계, 이미지 1/1
    • Pull up on the top of your keyboard with medium force. It should start to pop out.
    • A plastic opening tool may facilitate this task.
    • Run your hands underneath the edges of the keyboard until it is free from the device.
    • Do not pull hard to take the keyboard out. There is a small connection that needs to be undone.
  7. HP G60T-600 CTO CD Player Replacement: 7 단계, 이미지 1/2 HP G60T-600 CTO CD Player Replacement: 7 단계, 이미지 2/2
    • Place your thumbs on the two small, white tabs.
    • Push these tabs forward to release the connection and free the keyboard from the device.
  8. HP G60T-600 CTO CD Player Replacement, Power Button Frame: 8 단계, 이미지 1/1
    • Similarly to how you remove the keyboard, gently pry a small section of the power button frame up.
  9. HP G60T-600 CTO CD Player Replacement: 9 단계, 이미지 1/2 HP G60T-600 CTO CD Player Replacement: 9 단계, 이미지 2/2
    • Gently pull the white tab upwards.
    • With similar force, pull the connection out.
    • You are now free to pull the power button frame off of your device.
  10. HP G60T-600 CTO CD Player Replacement: 10 단계, 이미지 1/1
    • Unscrew the 5mm screw holding the CD player in place.
  11. HP G60T-600 CTO CD Player Replacement, CD Player: 11 단계, 이미지 1/3 HP G60T-600 CTO CD Player Replacement, CD Player: 11 단계, 이미지 2/3 HP G60T-600 CTO CD Player Replacement, CD Player: 11 단계, 이미지 3/3
    • Slide the CD player case away from the device with medium-hard force, it should come right out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Dominic DeSantis
회원 가입일: 10/19/16
748 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 4-5, Catania Fall 2016 UMass Dartmouth, Team 4-5, Catania Fall 2016 회원
UMASSD-CATANIA-F16S4G5
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 107
