주요 콘텐츠로 건너뛰기
HP G60T-600 CTO Hard drive Replacement
필요한 것
  1. HP G60T-600 CTO Hard drive Replacement, Battery: 1 단계, 이미지 1/1
    • Failure to remove the battery before performing any replacement guide may result in electric shock.
    • Close your device, then turn it over.
  2. HP G60T-600 CTO Hard drive Replacement: 2 단계, 이미지 1/2 HP G60T-600 CTO Hard drive Replacement: 2 단계, 이미지 2/2
    • Place your index finger on the ridged tab.
  3. HP G60T-600 CTO Hard drive Replacement: 3 단계, 이미지 1/1
    • Apply moderate pressure to the tab and slide it to the right.
    • While the tab is on the right, you should be able to gently slide your battery out of your device.
  4. HP G60T-600 CTO Hard drive Replacement, Hard drive: 4 단계, 이미지 1/2 HP G60T-600 CTO Hard drive Replacement, Hard drive: 4 단계, 이미지 2/2
    • Remove the 5cm screws with a #00 Phillips screwdriver.
    • Take the cover off.
  5. HP G60T-600 CTO Hard drive Replacement: 5 단계, 이미지 1/3 HP G60T-600 CTO Hard drive Replacement: 5 단계, 이미지 2/3 HP G60T-600 CTO Hard drive Replacement: 5 단계, 이미지 3/3
    • Remove the following .5cm screws with a #0 Phillips screwdriver.
    • Slide the hard drive cover to the right with light-medium force.
  6. HP G60T-600 CTO Hard drive Replacement: 6 단계, 이미지 1/1
    • Pull up on the little black tab on the hard drive case to remove it.
    • From here you will be able to carefully slide your hard drive out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Dominic DeSantis
회원 가입일: 10/19/16
748 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 4-5, Catania Fall 2016 UMass Dartmouth, Team 4-5, Catania Fall 2016 회원
UMASSD-CATANIA-F16S4G5
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 173
