주요 콘텐츠로 건너뛰기
HP G62 347NR CD/DVD Drive Replacement
필요한 것
  1. HP G62 347NR  CD/DVD Drive Replacement, CD/DVD Drive: 1 단계, 이미지 1/1
    • Make sure the device is turned off before removing the battery to avoid loss or corruption of files.
    • Turn the device over so the bottom is facing up.
    • Slide the battery release to the left until you hear a click.
    • Once you hear a click, the battery will have been released from the battery compartment.
  2. HP G62 347NR  CD/DVD Drive Replacement: 2 단계, 이미지 1/1
    • Remove the battery, carefully, from the compartment.
  3. HP G62 347NR  CD/DVD Drive Replacement: 3 단계, 이미지 1/1
    • Find the hard drive compartment with two Phillips head screws.
    • Use the PH1 screwdriver to loosen and remove both screws.
    • Gently remove the hard drive compartment.
  4. HP G62 347NR  CD/DVD Drive Replacement: 4 단계, 이미지 1/1
    • On the far left of the hard drive compartment, find the Phillips head screw.
    • Remove the Phillips head screw with the PH1 screwdriver.
  5. HP G62 347NR  CD/DVD Drive Replacement: 5 단계, 이미지 1/2 HP G62 347NR  CD/DVD Drive Replacement: 5 단계, 이미지 2/2
    • Get the plastic opening tool and place it between the laptop and the CD/DVD drive. Place it toward the center of the drive for maximum support.
    • Carefully pry the CD/DVD drive open.
    • Slide the CD/DVD drive out once it is pried open.
결론
McKenzi Morris
회원 가입일: 10/10/16
487 평판
안내서 3개 작성하였습니다
Texas Tech, Team 6-1, Bennett Fall 2016 Texas Tech, Team 6-1, Bennett Fall 2016 회원
TTU-BENNETT-F16S6G1
3 회원들
안내서 3개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 7
전체 시간: 429
