주요 콘텐츠로 건너뛰기
HP G62 347NR Keyboard Replacement
필요한 것
  1. HP G62 347NR Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Make sure the device is turned off before removing the battery to avoid loss or corruption of files.
    • Turn the device over so the bottom is facing up.
    • Slide the battery release to the left until you hear a click.
    • Once you hear a click, the battery will have been released from the battery compartment.
  2. HP G62 347NR Keyboard Replacement: 2 단계, 이미지 1/1
    • Remove the battery, carefully, from the compartment.
  3. HP G62 347NR Keyboard Replacement: 3 단계, 이미지 1/2 HP G62 347NR Keyboard Replacement: 3 단계, 이미지 2/2
    • Find the hard drive compartment with two Phillips head screws.
    • Use the PH1 screwdriver to loosen and remove both screws.
    • Gently remove the hard drive compartment.
  4. HP G62 347NR Keyboard Replacement: 4 단계, 이미지 1/2 HP G62 347NR Keyboard Replacement: 4 단계, 이미지 2/2
    • Locate the three Phillips head screws on the compartment with the wifi and keyboard logos.
    • Using the Phillips #1 screwdriver, remove the three screws.
  5. HP G62 347NR Keyboard Replacement: 5 단계, 이미지 1/2 HP G62 347NR Keyboard Replacement: 5 단계, 이미지 2/2
    • Locate the two keyboard logos on back of the computer.
    • Find the Phillips head screws in the hole next to the logo.
    • Remove the two screws using a Phillips #1 screwdriver.
  6. HP G62 347NR Keyboard Replacement: 6 단계, 이미지 1/2 HP G62 347NR Keyboard Replacement: 6 단계, 이미지 2/2
    • In the battery compartment, locate the three keyboard logos.
    • Find the Phillips head screws next to each logo.
    • Remove the three screws using the Phillips #1 screwdriver.
  7. HP G62 347NR Keyboard Replacement: 7 단계, 이미지 1/2 HP G62 347NR Keyboard Replacement: 7 단계, 이미지 2/2
    • Place the plastic opening tool between the keyboard and the motherboard.
    • Gently pry the entire keyboard up and away from the laptop's motherboard.
    • Once you have part of the keyboard separated, run your fingers around the edge of the keyboard to separate the entire thing.
결론
다른 3명이 해당 안내서를 완성하였습니다.
McKenzi Morris
회원 가입일: 10/10/16
511 평판
안내서 3개 작성하였습니다
Texas Tech, Team 6-1, Bennett Fall 2016 Texas Tech, Team 6-1, Bennett Fall 2016 회원
TTU-BENNETT-F16S6G1
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 16
전체 시간: 2,770
