주요 콘텐츠로 건너뛰기
HP G62 347NR Motherboard Replacement
필요한 것
  1. HP G62 347NR Motherboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Make sure the device is turned off before removing the battery to avoid loss or corruption of files.
    • Turn the device over so the bottom is facing up.
    • Slide the battery release to the left until you hear a click.
    • Once you hear a click, the battery will have been released from the battery compartment.
  2. HP G62 347NR Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the battery, carefully, from the compartment.
  3. HP G62 347NR Motherboard Replacement: 3 단계, 이미지 1/2 HP G62 347NR Motherboard Replacement: 3 단계, 이미지 2/2
    • Find the hard drive compartment with two Phillips head screws.
    • Use the PH1 screwdriver to loosen and remove both screws.
    • Gently remove the hard drive compartment.
  4. HP G62 347NR Motherboard Replacement: 4 단계, 이미지 1/2 HP G62 347NR Motherboard Replacement: 4 단계, 이미지 2/2
    • Locate the three Phillips head screws on the compartment with the wifi and keyboard logos.
    • Using the Phillips #1 screwdriver, remove the three screws.
  5. HP G62 347NR Motherboard Replacement: 5 단계, 이미지 1/2 HP G62 347NR Motherboard Replacement: 5 단계, 이미지 2/2
    • Locate the two keyboard logos on back of the computer.
    • Find the Phillips head screws in the hole next to the logo.
    • Remove the two screws using a Phillips #1 screwdriver.
  6. HP G62 347NR Motherboard Replacement: 6 단계, 이미지 1/2 HP G62 347NR Motherboard Replacement: 6 단계, 이미지 2/2
    • In the battery compartment, locate the three keyboard logos.
    • Find the Phillips head screws next to each logo.
    • Remove the three screws using the Phillips #1 screwdriver.
  7. HP G62 347NR Motherboard Replacement: 7 단계, 이미지 1/2 HP G62 347NR Motherboard Replacement: 7 단계, 이미지 2/2
    • Place the plastic opening tool between the keyboard and the motherboard.
    • Gently pry the entire keyboard up and away from the laptop's motherboard.
    • Once you have part of the keyboard separated, run your fingers around the edge of the keyboard to separate the entire thing.
  8. HP G62 347NR Motherboard Replacement, Remove palmrest: 8 단계, 이미지 1/3 HP G62 347NR Motherboard Replacement, Remove palmrest: 8 단계, 이미지 2/3 HP G62 347NR Motherboard Replacement, Remove palmrest: 8 단계, 이미지 3/3
    • Remove the single M2.5x5 blue-painted screw securing the palmrest, from under where the keyboard was.
    • Remove the connectors from the motherboard.
    • Close the laptop's screen, and flip the laptop over.
    • Remove the twelve M2.5x6.5 red-painted screws.
    • Remove the four M2.5x3 screws securing the palmrest to the base.
    • Remove the screw for the wireless card, as well as the wireless antennas, and take the wireless card out.
  9. HP G62 347NR Motherboard Replacement, Remove motherboard: 9 단계, 이미지 1/1
    • Remove the two blue-painted M2.5x4 screws securing the motherboard to the base.
    • Remove all connectors from the motherboard.
    • Transfer your heatsink, processor, and memory to the replacement board. You're done!
결론
Joseph Sctbunio
회원 가입일: 09/23/17
7,030 평판
안내서 42개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 17
전체 시간: 1,319
