주요 콘텐츠로 건너뛰기
HP G62-144DX Hard Drive Replacement
필요한 것
  1. HP G62-144DX Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 HP G62-144DX Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure to turn off the laptop before removing the battery.
    • Slide the lock to the right, located slightly above the battery location.
    • While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  2. HP G62-144DX Hard Drive Replacement, Hard Drive: 2 단계, 이미지 1/3 HP G62-144DX Hard Drive Replacement, Hard Drive: 2 단계, 이미지 2/3 HP G62-144DX Hard Drive Replacement, Hard Drive: 2 단계, 이미지 3/3
    • Loosen the 2 Phillips 2.5x6 screws in the rectangular panel with a Phillips #1 screwdriver.
    • The screws will stay in the panel, but come free from the body of the computer.
    • Gently remove the panel with a plastic opening tool.
  3. HP G62-144DX Hard Drive Replacement: 3 단계, 이미지 1/3 HP G62-144DX Hard Drive Replacement: 3 단계, 이미지 2/3 HP G62-144DX Hard Drive Replacement: 3 단계, 이미지 3/3
    • Unscrew the three 3x4 Phillips screws holding the hard drive in with a Phillips #1 screwdriver.
    • Pull the hard drive cable out of the motherboard.
    • Pull the hard drive out of the computer.
결론
Cameron Moran
회원 가입일: 10/18/17
623 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S4-G8, Julie Fall 2017 UMass Dartmouth, Team S4-G8, Julie Fall 2017 회원
UMASSD-JULIE-F17S4G8
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 340
