주요 콘텐츠로 건너뛰기
HP G62-144DX Keyboard Replacement
필요한 것
  1. HP G62-144DX Keyboard Replacement, Battery: 1 단계, 이미지 1/2 HP G62-144DX Keyboard Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure to turn off the laptop before removing the battery.
    • Slide the lock to the right, located slightly above the battery location.
    • While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  2. HP G62-144DX Keyboard Replacement, Keyboard: 2 단계, 이미지 1/1
    • Remove the 3 Phillips 2.5x5 screws (closest to the battery slot) and the 2 Phillips 2.5x6.5 screws with a Phillips #1 screwdriver.
    • This screws will have a keyboard symbol inscribed next to them.
  3. HP G62-144DX Keyboard Replacement: 3 단계, 이미지 1/3 HP G62-144DX Keyboard Replacement: 3 단계, 이미지 2/3 HP G62-144DX Keyboard Replacement: 3 단계, 이미지 3/3
    • Use the Phillips # 1 screwdriver to unscrew the 2.5x6 Phillips screws holding the L-shaped back panel.
    • Screws should stay in panel, but come free of the laptop body.
    • Gently use a plastic opening tool to remove the panel.
  4. HP G62-144DX Keyboard Replacement: 4 단계, 이미지 1/2 HP G62-144DX Keyboard Replacement: 4 단계, 이미지 2/2
    • Unscrew the final Phillips 2.5x5 keyboard screw with a Phillips #1 screwdriver.
  5. HP G62-144DX Keyboard Replacement: 5 단계, 이미지 1/2 HP G62-144DX Keyboard Replacement: 5 단계, 이미지 2/2
    • Flip the laptop so the top is facing up again and open the cover.
    • Use a metal spudger to pry the keyboard up and pull it back.
    • Be sure to pry up the board itself and not an individual key.
    • This process has the risk of breaking keys.
  6. HP G62-144DX Keyboard Replacement: 6 단계, 이미지 1/2 HP G62-144DX Keyboard Replacement: 6 단계, 이미지 2/2
    • Pull up the latch that connects the keyboard connector the the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Cameron Moran
회원 가입일: 10/18/17
623 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S4-G8, Julie Fall 2017 UMass Dartmouth, Team S4-G8, Julie Fall 2017 회원
UMASSD-JULIE-F17S4G8
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 619
