소개
The keyboard may not be working for a variety of reasons and may need to be replaced.
필요한 것
Slide the lock to the right, located slightly above the battery location.
While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
Remove the 3 Phillips 2.5x5 screws (closest to the battery slot) and the 2 Phillips 2.5x6.5 screws with a Phillips #1 screwdriver.
다른 2명이 해당 안내서를 완성하였습니다.
