주요 콘텐츠로 건너뛰기
HP G62-223CL Hard Drive Replacement
필요한 것
  1. HP G62-223CL Hard Drive Replacement, Battery Removal: 1 단계, 이미지 1/2 HP G62-223CL Hard Drive Replacement, Battery Removal: 1 단계, 이미지 2/2
    • Removing the battery while the laptop is still on may corrupt your files.
    • Turn the device over to expose the bottom of the device.
    • Slide the battery release all the way to the left.
    • There will be a click and the battery will be released from its compartment.
  2. HP G62-223CL Hard Drive Replacement: 2 단계, 이미지 1/1
    • Carefully remove the battery from its compartment.
  3. HP G62-223CL Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/2 HP G62-223CL Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2/2
    • Locate the two Phillips head retaining screws which secure the hard drive compartment.
    • Use a Phillips #0 screwdriver to loosen the retaining screws.
    • Remove the panel covering the compartment.
    • Ground yourself before attempting to touch any components. To ground yourself, touch a conductive metal to eliminate any static buildup in your body, which can damage computer components.
  4. HP G62-223CL Hard Drive Replacement: 4 단계, 이미지 1/1
    • Locate the three 6 mm Phillips head screws for the hard drive.
    • Use a Phillips #0 screwdriver to remove the screws.
  5. HP G62-223CL Hard Drive Replacement: 5 단계, 이미지 1/1
    • Remove the hard drive from the compartment.
    • Pull the connector cable from the end of the hard drive.
  6. HP G62-223CL Hard Drive Replacement: 6 단계, 이미지 1/1
    • Locate the two 6 mm Phillips head screws on each side of the hard drive.
    • Remove the cover from the hard drive.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Garret Layton
회원 가입일: 01/13/15
669 평판
안내서 5개 작성하였습니다
USF Tampa, Team 1-4, Sullivan Winter 2015 USF Tampa, Team 1-4, Sullivan Winter 2015 회원
USFT-SULLIVAN-W15S1G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 14
전체 시간: 2,649
