주요 콘텐츠로 건너뛰기
HP G62-234DX Wi-Fi Card Replacement
필요한 것
  1. HP G62-234DX Wi-Fi Card Replacement, Wi-Fi Card: 1 단계, 이미지 1/3 HP G62-234DX Wi-Fi Card Replacement, Wi-Fi Card: 1 단계, 이미지 2/3 HP G62-234DX Wi-Fi Card Replacement, Wi-Fi Card: 1 단계, 이미지 3/3
    • Make sure the computer is turned off and disconnected from a charger.
    • Place your laptop on a clean, flat surface with the bottom facing up.
    • Slide the battery lock to the left.
    • Slide the battery out from the laptop while holding the lock to the left.
    • Remove the battery.
  2. HP G62-234DX Wi-Fi Card Replacement: 2 단계, 이미지 1/3 HP G62-234DX Wi-Fi Card Replacement: 2 단계, 이미지 2/3 HP G62-234DX Wi-Fi Card Replacement: 2 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to remove the three 6.0 mm screws.
    • The screws that are attached to the panel do not need to be removed completely.
    • Remove the back panel to access the Wi-Fi card.
  3. HP G62-234DX Wi-Fi Card Replacement: 3 단계, 이미지 1/3 HP G62-234DX Wi-Fi Card Replacement: 3 단계, 이미지 2/3 HP G62-234DX Wi-Fi Card Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Slide a thin, ESD-safe pry tool or tweezers under the wire until it's snug against the connector, and pry straight up from the board to disconnect the coaxial cables from the Wi-Fi card.
  4. HP G62-234DX Wi-Fi Card Replacement: 4 단계, 이미지 1/2 HP G62-234DX Wi-Fi Card Replacement: 4 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the 3.0 mm screw from the Wi-Fi card.
    • When the screw is removed the card will pop up at a 45-degree angle.
  5. HP G62-234DX Wi-Fi Card Replacement: 5 단계, 이미지 1/3 HP G62-234DX Wi-Fi Card Replacement: 5 단계, 이미지 2/3 HP G62-234DX Wi-Fi Card Replacement: 5 단계, 이미지 3/3
    • Remove the Wi-Fi card by sliding it out from the socket.
결론
To reassemble your device, follow these instructions in reverse order. Make sure to be careful when attaching the wires back into the Wi-Fi card, they can be very fragile.
다른 한 분이 해당 안내서를 완성하였습니다.
Kate Ferland
회원 가입일: 11/01/23
836 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 1-1, Petersen Fall 2023 UMass Dartmouth, Team 1-1, Petersen Fall 2023 회원
UMASSD-PETERSEN-F23S1G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 138
