주요 콘텐츠로 건너뛰기
HP G62-340US Hard Drive Replacement
필요한 것
  1. HP G62-340US Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Turn off the computer and disconnect the charging cable from the computer.
    • Turn your laptop over and locate the hard drive module compartment.
  2. HP G62-340US Hard Drive Replacement: 2 단계, 이미지 1/1
    • Use a screwdriver to loosen the two Phillips PM2.5x6.0 captive screws on the hard drive cover.
    • Lift the left side of the hard drive cover and remove the cover.
  3. HP G62-340US Hard Drive Replacement: 3 단계, 이미지 1/3 HP G62-340US Hard Drive Replacement: 3 단계, 이미지 2/3 HP G62-340US Hard Drive Replacement: 3 단계, 이미지 3/3
    • Use a screwdriver to remove the three Phillips PM3.0x4.0 screws on the hard drive.
  4. HP G62-340US Hard Drive Replacement: 4 단계, 이미지 1/1
    • Disconnect the hard drive cable from the system board and gently remove the hard drive.
  5. HP G62-340US Hard Drive Replacement: 5 단계, 이미지 1/3 HP G62-340US Hard Drive Replacement: 5 단계, 이미지 2/3 HP G62-340US Hard Drive Replacement: 5 단계, 이미지 3/3
    • Remove the 4 screws from the hard drive bracket and separate it from the hard drive.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Yun Yang
회원 가입일: 10/19/17
336 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S1-G4, Isaacson Fall 2017 UMass Dartmouth, Team S1-G4, Isaacson Fall 2017 회원
UMASSD-ISAACSON-F17S1G4
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 9
전체 시간: 1,254
