주요 콘텐츠로 건너뛰기
HP G71t-400 RAM Replacement
필요한 것
  1. HP G71t-400 RAM Replacement, RAM: 1 단계, 이미지 1/3 HP G71t-400 RAM Replacement, RAM: 1 단계, 이미지 2/3 HP G71t-400 RAM Replacement, RAM: 1 단계, 이미지 3/3
    • Lay the laptop down so the bottom is facing up.
    • Push the slide button, circled in photo 1, to release the battery.
    • Action in picture 2 shows the direction and release.
    • Tilt the battery back in the direction it popped up in and remove the battery.
    • This ensures there is no power in the system that could potentially short out any components.
  2. HP G71t-400 RAM Replacement: 2 단계, 이미지 1/3 HP G71t-400 RAM Replacement: 2 단계, 이미지 2/3 HP G71t-400 RAM Replacement: 2 단계, 이미지 3/3
    • Remove the circled screws.
    • Lift and remove the cover, exposing the RAM cards.
  3. HP G71t-400 RAM Replacement: 3 단계, 이미지 1/1
    • Push in the silver tabs to release the RAM.
    • When they pop up from the locked position the RAM may be removed.
결론
Nicholas Castro
회원 가입일: 03/24/19
711 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S1-G5, Simcock Spring 2019 UMass Dartmouth, Team S1-G5, Simcock Spring 2019 회원
UMASSD-SIMCOCK-S19S1G5
2 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 82
