주요 콘텐츠로 건너뛰기
HP HDX 16-1160US DVD Drive Replacement
필요한 것
  1. HP HDX 16-1160US DVD Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the device over so that the bottom side is facing up and the battery is facing away from you.
  2. HP HDX 16-1160US DVD Drive Replacement: 2 단계, 이미지 1/3 HP HDX 16-1160US DVD Drive Replacement: 2 단계, 이미지 2/3 HP HDX 16-1160US DVD Drive Replacement: 2 단계, 이미지 3/3
    • Locate the slider under the right side of the battery.
    • Using your thumb, slide it all the way to the left until the front of the battery lifts up.
  3. HP HDX 16-1160US DVD Drive Replacement: 3 단계, 이미지 1/1
    • With your thumb still holding the slider to the left, use the opposite hand to lift the battery out, removing it from the computer.
  4. HP HDX 16-1160US DVD Drive Replacement, Keyboard: 4 단계, 이미지 1/1
    • Remove the three 4mm screws using Phillips #1 screw driver.
    • Remove the four 6mm screws using Phillips #1 screw driver.
    • Remove the two 3mm screws using Phillips #1 screw driver.
  5. HP HDX 16-1160US DVD Drive Replacement: 5 단계, 이미지 1/1
    • Using your fingers, pry off the speaker cover.
  6. HP HDX 16-1160US DVD Drive Replacement: 6 단계, 이미지 1/3 HP HDX 16-1160US DVD Drive Replacement: 6 단계, 이미지 2/3 HP HDX 16-1160US DVD Drive Replacement: 6 단계, 이미지 3/3
    • Use the plastic opener to pry up the chrome keyboard cover from the lab top itself. Carefully work around the edges by prying each snap individually.
    • Remove the chrome keyboard cover.
    • Be careful not to pull the chrome cover completely off because there is a black strip connecting it to the laptop itself.
  7. HP HDX 16-1160US DVD Drive Replacement: 7 단계, 이미지 1/3 HP HDX 16-1160US DVD Drive Replacement: 7 단계, 이미지 2/3 HP HDX 16-1160US DVD Drive Replacement: 7 단계, 이미지 3/3
    • Locate and remove the two 4mm screws with the Phillips #1 screw driver.
  8. HP HDX 16-1160US DVD Drive Replacement: 8 단계, 이미지 1/2 HP HDX 16-1160US DVD Drive Replacement: 8 단계, 이미지 2/2
    • Using your hands, pull the keyboard out.
    • Do not pull completely off because there is a grey strip connecting it to the laptop itself.
  9. HP HDX 16-1160US DVD Drive Replacement: 9 단계, 이미지 1/2 HP HDX 16-1160US DVD Drive Replacement: 9 단계, 이미지 2/2
    • Lift the black tab using the plastic opening tool.
    • Gently pull the grey strip out, horizontally way from you. This will release the keyboard from the computer.
  10. HP HDX 16-1160US DVD Drive Replacement, DVD Drive: 10 단계, 이미지 1/1
    • Use the Phillips #1 Screw Driver to unscrew the 5mm screw.
  11. HP HDX 16-1160US DVD Drive Replacement: 11 단계, 이미지 1/1
    • Flip over the device so that the bottom side is facing up.
    • Use the Phillips #1 Screw Driver to unscrew the 7mm screw near the center of the device.
  12. HP HDX 16-1160US DVD Drive Replacement: 12 단계, 이미지 1/1
    • Push down and pull out the DVD on the left side of the device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Marshall Reid
회원 가입일: 04/14/14
527 평판
안내서 3개 작성하였습니다
Cal Poly, Team 12-38, Maness Spring 2014 Cal Poly, Team 12-38, Maness Spring 2014 회원
CPSU-MANESS-S14S12G38
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 15
전체 시간: 1,457
