필요한 것
Turn the device over so that the bottom side is facing up and the battery is facing away from you.
Remove the three 4mm screws using Phillips #1 screw driver.
Remove the four 6mm screws using Phillips #1 screw driver.
Remove the two 3mm screws using Phillips #1 screw driver.
거의 끝나갑니다!
결론
다른 3명이 해당 안내서를 완성하였습니다.
