주요 콘텐츠로 건너뛰기
HP HDX 16-1160US Wifi Card Replacement
필요한 것
  1. HP HDX 16-1160US Wifi Card Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the device over so that the bottom side is facing up and the battery is facing away from you.
  2. HP HDX 16-1160US Wifi Card Replacement: 2 단계, 이미지 3개 중 1개 HP HDX 16-1160US Wifi Card Replacement: 2 단계, 이미지 3개 중 2개 HP HDX 16-1160US Wifi Card Replacement: 2 단계, 이미지 3개 중 3개
    • Locate the slider under the right side of the battery.
    • Using your thumb, slide it all the way to the left until the front of the battery lifts up.
  3. HP HDX 16-1160US Wifi Card Replacement: 3 단계, 이미지 1개 중 1개
    • With your thumb still holding the slider to the left, use the opposite hand to lift the battery out, removing it from the computer.
  4. HP HDX 16-1160US Wifi Card Replacement, Wifi Card: 4 단계, 이미지 2개 중 1개 HP HDX 16-1160US Wifi Card Replacement, Wifi Card: 4 단계, 이미지 2개 중 2개
    • Use the Phillips #1 Screw Driver to unscrew the 6mm screw from the Wi-Fi Card Panel.
    • The 6mm screw will remain in the Wi-Fi card panel and will not fall out.
    • Lift off the Wi-Fi card panel off using the opposite hand.
  5. HP HDX 16-1160US Wifi Card Replacement: 5 단계, 이미지 2개 중 1개 HP HDX 16-1160US Wifi Card Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the gray and black wires by gently pulling up on them so that they "unsnap" from the Wi-Fi card.
  6. HP HDX 16-1160US Wifi Card Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the two 4mm screws with the Phillips #1 screw driver.
  7. HP HDX 16-1160US Wifi Card Replacement: 7 단계, 이미지 1개 중 1개
    • Carefully use the plastic opening tools to lift the Wi-Fi card up on the left side.
    • Using the opposite hand, pull the Wi-Fi card to the left.
    • Do not lift the Wi-Fi card straight up, this will damage or break the Wi-Fi card.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Marshall Reid
회원 가입일: 04/14/14
527 평판
안내서 3개를 작성함
Cal Poly, Team 12-38, Maness Spring 2014 Cal Poly, Team 12-38, Maness Spring 2014 회원
CPSU-MANESS-S14S12G38
4 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 1,168
