주요 콘텐츠로 건너뛰기
HP LaserJet 1160 or 1320 Control Panel Replacement
필요한 것
  1. HP LaserJet 1160 or 1320 Control Panel Replacement, Left Side Cover: 1 단계, 이미지 1/3 HP LaserJet 1160 or 1320 Control Panel Replacement, Left Side Cover: 1 단계, 이미지 2/3 HP LaserJet 1160 or 1320 Control Panel Replacement, Left Side Cover: 1 단계, 이미지 3/3
    • Pull on the two tabs on the back of the printer to release the left side cover.
    • Remove the cover by rotating it towards the front of the printer.
  2. HP LaserJet 1160 or 1320 Control Panel Replacement, Right Side Cover: 2 단계, 이미지 1/3 HP LaserJet 1160 or 1320 Control Panel Replacement, Right Side Cover: 2 단계, 이미지 2/3 HP LaserJet 1160 or 1320 Control Panel Replacement, Right Side Cover: 2 단계, 이미지 3/3
    • With the printer turned so that the right side is facing upwards, use a metal spudger to disengage 3 tabs holding the right side cover in place.
    • Lift the cover off of the printer.
  3. HP LaserJet 1160 or 1320 Control Panel Replacement, Back Cover: 3 단계, 이미지 1/3 HP LaserJet 1160 or 1320 Control Panel Replacement, Back Cover: 3 단계, 이미지 2/3 HP LaserJet 1160 or 1320 Control Panel Replacement, Back Cover: 3 단계, 이미지 3/3
    • Remove 4 screws on the back of the printer.
    • Remove the back cover.
  4. HP LaserJet 1160 or 1320 Control Panel Replacement, Top Cover: 4 단계, 이미지 1/3 HP LaserJet 1160 or 1320 Control Panel Replacement, Top Cover: 4 단계, 이미지 2/3 HP LaserJet 1160 or 1320 Control Panel Replacement, Top Cover: 4 단계, 이미지 3/3
    • Remove 2 screws on the back of the printer, one on the left, and one on the front.
    • The second image shows the formatter removed, but it is not necessary to remove the formatter to replace the top cover.
  5. HP LaserJet 1160 or 1320 Control Panel Replacement, Top Cover: 5 단계, 이미지 1/1
    • Disconnect the control panel cable and remove the top cover.
  6. HP LaserJet 1160 or 1320 Control Panel Replacement, Control Panel: 6 단계, 이미지 1/3 HP LaserJet 1160 or 1320 Control Panel Replacement, Control Panel: 6 단계, 이미지 2/3 HP LaserJet 1160 or 1320 Control Panel Replacement, Control Panel: 6 단계, 이미지 3/3
    • Use a metal spudger to remove the control panel and its circuit board from the top cover.
결론
jdp23
회원 가입일: 08/22/13
1,302 평판
안내서 23개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 698
